Went out and double checked all of those and they are fine. I'm thinking it may be the bypass valve or oil pump. The pressure comes up from just above 0 after about 1300 RPM and quickly goes just above 50 psi, but it never goes higher than that no matter how hard I hit the throttle. Is it possible I have it wired in a bad spot? I have the power hooked to my ignition and the ground running to the dash support. I just hope it's something fairly inexpensive and easy to replace!
