Thread: Low Oil Pressure?!?!
Results 1 to 20 of 37
  1. #1 Re: Low Oil Pressure?!?!
    Hoffman/Schaumburg, IL
    Low oil pressure could be a sign of a worn bearings, cause when there is room, they just bleed pressure off and it doesn't reach the higher parts of the motor....
    Pull the front valve cover and run the engine at idle, there should be oil flowing over the rockers, from the intake side towards the radiator, may not be a lot. but, if the rockers are running dry you may have a bearing or pump problem problem( you may be able to just remove the oil cap and see)
    Hopefully it isn't anything major
  2. #2 Re: Low Oil Pressure?!?!
    Feb 2008
    I'll change the filter tomorrow and, if things don't change, I'll check the rockers.
  1. ABS and Tire Pressure Lights on
    By adidasdude1061 in forum Brakes/Suspension/Chassis
    Last Post: 02-16-2010, 10:05 PM
  2. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
  3. Oil Pressure Sensor
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2008, 12:11 PM
  4. question: eletric oil pressure
    By fst in forum General Tech Discussion
    Last Post: 06-23-2008, 09:21 PM
  5. how to use a fuel pressure gauge?
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2008, 01:06 PM
