Thread: Low Oil Pressure?!?!
Results 1 to 20 of 37
  1. #1 Re: Low Oil Pressure?!?!
    Feb 2008
    Well... I fired it up and pulled the cap off. I was unable to see any oil squirting, but since I don't really know exactly where to look, that may not be a definite conclusion. There was visible oil puddled around the head bolt, however.
    I killed it and touched both of the exposed rockers and neither felt very wet with oil. Should it be squirting immediately after a cold start-up, or will it take a few minutes? I only ran the car a minute or so.
    Now that I think about it, I recall at an earlier time (before the oil change and this problem) seeing plenty of oil when I opened the cap. It's funny that this problem did not seem to appear until after this recent oil change. Could I have possibly gotten a piece of sludge stuck in one of the oil passages? I did run a SMALL amount of seafoam through the crank case 10 minutes before changing the oil. Also, I switched from Mobil 1 Extended Performance 10W-30 to Royal Purple 10W-30. Is there enough of a difference between the two to bring an issue like this to a head?
  1. ABS and Tire Pressure Lights on
    By adidasdude1061 in forum Brakes/Suspension/Chassis
    Last Post: 02-16-2010, 10:05 PM
  2. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
  3. Oil Pressure Sensor
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2008, 12:11 PM
  4. question: eletric oil pressure
    By fst in forum General Tech Discussion
    Last Post: 06-23-2008, 09:21 PM
  5. how to use a fuel pressure gauge?
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2008, 01:06 PM
