Thread: what should i spend $2k on for 98 gtp
Results 21 to 40 of 70
  1. #21 Re: what should i spend $2k on for 98 gtp
    tennessee
    would i be safe running zzp cnc heads w/3.4 and overkill pcm on stock trans(shifts very well imo)???
  2. #22 Re: what should i spend $2k on for 98 gtp
    Don't waste your money on ZZP heads.
    Seriously.
  3. #23 Re: what should i spend $2k on for 98 gtp
    tennessee
    ok then whos heads should i run? i cannot afford a trans from tep
  4. #24 Re: what should i spend $2k on for 98 gtp
    tennessee
    i guess ill go with the 3.4 pully and an overkill pcm on a morad engine and trans
  5. #25 Re: what should i spend $2k on for 98 gtp
    Got headers?
    Or flow mods?
    If not...keep the stock pulley guy.
  6. #26 Re: what should i spend $2k on for 98 gtp
    tennessee
    i have headers 3" cat back and an intake
  7. #27 Re: what should i spend $2k on for 98 gtp
    Well cam it then and skip this other nonsense...drive it till the wheels fall off.
  8. #28 Re: what should i spend $2k on for 98 gtp
    tennessee
    ok so s1x it is... maybe vs
  9. #29 Re: what should i spend $2k on for 98 gtp
    Well your easy to convince...I need some bills paid too...since you got 2G's and all...buddddddddddddddy
  10. #30 Re: what should i spend $2k on for 98 gtp
    tennessee
    wait with my headers and intake if i add a cam will i b able to drop to a 3.4?
  11. #31 Re: what should i spend $2k on for 98 gtp
    Probably to a 3.25" or lower...
    But you will NEED a tune at that point.
  12. #32 Re: what should i spend $2k on for 98 gtp
    tennessee
    i was thinking about an overkill pcm... im gonna try to keep it simple so i dont blow it sky high... it is my dd
  13. #33 Re: what should i spend $2k on for 98 gtp
    A canned tune isn't best for a cam setup...have you checked for any local tuners in Tenn.?
    I'm sure there are some.
  14. #34 Re: what should i spend $2k on for 98 gtp
    tennessee
    I've been looking for one for a while there are plenty of dynos within about 30 miles of me but idk if they'll b setup to tune a gtp...
  15. #35 Re: what should i spend $2k on for 98 gtp
    tennessee
    I think I'm sadly gonna have to go with a morad motor trans combo for 1500... kinda makes me want to sell mine and get an older trans am
  16. #36 Re: what should i spend $2k on for 98 gtp
    Florida
    Hows the motor and Trans run??
    Theres no need to spend $1500 on a motor/trans if your's are good.
  17. #37 Re: what should i spend $2k on for 98 gtp
    tennessee
    i just changed the lim gasket about a month ago and looked at the valves as best as i could they didnt seem to have much build up on them... the sc rotors could probably use a good recoating... its gonna need wheel bearings soon... trans fluid is always a very nice red color, oil drain plug has minimal to no shavings on it at oil changes... acceleration was better before the headers and exhaust but i was expecting that due to loss in back pressure... and itll still get up to 126mph (governor) no problem...
  18. #38 Re: what should i spend $2k on for 98 gtp
    tennessee
    im just gonna get ported lim, new wheel bearings, aeroforce interceptor, 3.4" pulley, and maybe an ls1 tb... the obnoxious thread may be closed now as questions have been answered... thank you all very much
  19. #39 Re: what should i spend $2k on for 98 gtp
    What is the point of an LS1 on a 3.4" setup? Not needed.
    Click the link in mah sig brah
  20. #40 Re: what should i spend $2k on for 98 gtp
    tennessee
    ive read your thread multiple times and its amazing... its why i got the headers before everything... and i was just throwin the ls1 throttle body for the halibut... so ur sayin i should just get a tb from reptile or just port my own??? or just leave it an l67???
  1. How I spend my weekends....
    Last Post: 04-01-2011, 10:33 AM
  2. how much should i spend?
    By savannaz34 in forum Off Topic Discussion
    Last Post: 08-22-2010, 10:02 PM
  3. 300 bucks to spend what to buy?
    By killakross5o4 in forum Off Topic Discussion
    Last Post: 02-16-2010, 07:20 AM
  4. I've got $800 to spend on my GP GT...
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2008, 04:04 PM
