Thread: what should i spend $2k on for 98 gtp
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 70
  1. #1 Intercooler
    tennessee
    ok so zzp and prj all use heater cores sandwiched between the sc and lim so what if i ran something like this Liquid To Air Power Coolers Performance Racing Products for International Sales from SSAutochrome Inc. which uses a custom radiator design, with a bosch pump, zzp heat exchanger and a zzp ic pump controller??? would this make about the same power or will it not work at all??? im fixing to drop to a 3.35" pulley , reconditioned heads, ported lim and an overkill tuned pcm, already have the headers and custom intake installed, gonna try to keep stock cam and rockers for now as it'll b my dd...
  2. #2 what should i spend $2k on for 98 gtp
    tennessee
    ok so what should i do with my 1998 gtp with 205,600 moderately driven regularly maintained miles on it??? im looking for about 300whp maybe more. i already have header back exhaust and intake... i was thinking zzp reconditioned heads with an ssac intercooler with a zzp heat exchanger, bosch pump, zzp intercooler controller and ported lim with an overkill pcm, but im open to all suggestions... link to ssac ic. Liquid To Air Power Coolers Performance Racing Products for International Sales from SSAutochrome Inc.
  3. #3 Re: what should i spend $2k on for 98 gtp
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    With those miles I would keep the money for a new motor an trans and suspension... But headers are a must, zzp reconditioned heads are a waste of money, just have a machine shop redo yours if there's anything even wrong with them, or buy a used set of low mile l32 heads with the slightly bigger valves. and the ssic intercooler setup isn't worth it, spend a tad more and at least get the stage 2 core and fmhe. and of course get or make a nice intake setup
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  4. #4 Re: what should i spend $2k on for 98 gtp
    Florida
    I'd spend the money on a good trans. And rebuild the top end of the motor. The last thing you want is to spend $2000 on go-fast mods, and have the engine blow.
    205K miles is up there, so make sure everything is up to snuff before you go modding.
    Also, I dont think the Water to air IC is very viable...least I've never seen any car running them besides the Aussie 3.8 RWDs.
  5. #5 Re: what should i spend $2k on for 98 gtp
    tennessee
    thanks guys the top end is where i was gonna focus all the money and i did forget to mention that i already have kyb gr-2's with the eibachs and anti pogos... the ride is amazing...so ur sayin the ssac ic isnt worth the $135 shipped and i should get a morad trans and engine... just saw a motor trans combo on miorads ebay site for $1599+shipping w/110k mi
  6. #6 Re: what should i spend $2k on for 98 gtp
    tennessee
    i also found this on morad's ebay store Grand Prix GTP Steering Column Tapshift Tap Shift Kit | eBay does anyone think this tap shift conversion would work and be worth anything performance wise?
  7. #7 Re: what should i spend $2k on for 98 gtp
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    I like my SSIC, I was able to go from a 3.5 pulley with 17degrees WOT timing to a 3.25 pulley with 19 wot timing and a 12.0 AFR. Is it as good as a fullsize. No. Does it work? yes
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  8. #8 Re: what should i spend $2k on for 98 gtp
    Florida
    its not SSIC...its SSAC..totally different intercooler.
    Ones liquid---liquid
    The other is liquid-air.
    I wouldnt get just a stock transmission. If you're planning on putting down 300hp, your gonna start tearing up stock trannies.
    See about a TEP tranny, or similar trannies.
    I'd say if the bottom end is good, just rebuild the top, with go fast stuff, and be happy.
  9. #9 Re: $1000 for intercooler.....
    Mercer, Pa
    Quote Originally Posted by mskram1 View Post
    Liquid To Air Power Coolers Performance Racing Products?????????
    This doesn't fit between the supercharger and the lower intake manifold on a 3800, is that what you asking?
  10. #10 Re: Intercooler
    Make a new thread next time.
    Thanks.
  11. #11 Re: Intercooler
    tennessee
    sorry i wasnt clear sseilmnop i know that it doesnt fi under the sc i was just wanting some opinions on that setup and its pros and cons but i think im just gonna go for a morad motor trans combo and not do any go fast mods this year as im limitid to 2k
  12. #12 Re: what should i spend $2k on for 98 gtp
    Merged your threads.
    Keep it all in one since they're all on the same topic.
  13. #13 Re: what should i spend $2k on for 98 gtp
    tennessee
    ok but a tep trans is like my whole budget
  14. #14 Re: what should i spend $2k on for 98 gtp
    tennessee
    and thank you sir for merging that for me
  15. #15 Re: what should i spend $2k on for 98 gtp
    Florida
    BUTTT. Get 3.29 gearing, and you'll be faster!
    Theres no point in trying to make big power, if you cant get it to the ground effectively.
    A basic 3.4" setup will be fine, anything more and you'll be pissed when you have a messed tranny.
  16. #16 Re: what should i spend $2k on for 98 gtp
    tennessee
    good infos... looks like i went from getting lots of power to just trying to keep it alive... lol
  17. #17 Re: what should i spend $2k on for 98 gtp
    tennessee
    and tep does have a 3.29 option... ill have to get a new pcm with that too right
  18. #18 Re: what should i spend $2k on for 98 gtp
    Someone dare put 3.69's in a race transmission with a custom tune on a stock pullied car with slicks and get close to 12's?
    Do it.
  19. #19 Re: what should i spend $2k on for 98 gtp
    tennessee
    wait a sec... 3.29's or3.69's... im confused but i could live with that so who should i buy the pcm from???
  20. #20 Re: what should i spend $2k on for 98 gtp
    Florida
    Get a custom tune if your modded, if not, get either a Reptile(member on here) or an Overkill pcm.
    3.69s will get better acceleration, but sacrifice MPG, due to the gearing.
    3.29s came in GT's and are geared better for acceleration than the GTPs 2.93 gears.
  1. How I spend my weekends....
    Last Post: 04-01-2011, 10:33 AM
  2. how much should i spend?
    By savannaz34 in forum Off Topic Discussion
    Last Post: 08-22-2010, 10:02 PM
  3. 300 bucks to spend what to buy?
    By killakross5o4 in forum Off Topic Discussion
    Last Post: 02-16-2010, 07:20 AM
  4. I've got $800 to spend on my GP GT...
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2008, 04:04 PM
