Thread: Won't start after cam install
Page 14 of 19 FirstFirst ... 41213141516 ... LastLast
Results 261 to 280 of 448
  1. #1 Re: Won't start after cam install
    Grand Rapids, MI
    Quote Originally Posted by Bedwards View Post
    Yes. Exchanging it now.
    good! fixin to say, take it back and cut up sideways..
  2. #2 Re: Won't start after cam install
    Topeka, KS
    Good. So we hear it go VRRRRRRRRROOOOOOOOOM tomorrow ?
  3. #3 Re: Won't start after cam install
    Grand Rapids, MI
    again, vid is required
  4. #4 Re: Won't start after cam install
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    I fricken hope so!!!
  5. #5 Re: Won't start after cam install
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    Good luck!
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  6. #6 Re: Won't start after cam install
    Some of the valve seals are wrecked, so I'm going to replace those. However, I don't have the spark plug air adapter so I won't be able to get it running until tomorrow at the earliest. Always something.
  7. #7 Re: Won't start after cam install
    swift current,sask.
    Worst case, use some para cord in the spark plug hole. Just get it to the bottom of the intake stroke or whatever, jam as much rope in there as possible and hand turn it to the compression stroke until it gets hard to turn. and take the spring off. I don't like air, you drop that valve somehow you are screwed.
  8. #8 Re: Won't start after cam install
    Quote Originally Posted by whiney View Post
    The valve won't drop if the piston is at TDC.
  9. #9 Re: Won't start after cam install
    Changed all the valve seals. Got the rest of the valvetrain (pushrods, rockers etc.) assembled and torqued. I turned my motor over by hand and it is turning over WAY easier than before. No binding or strange sounds. All the valves are opening how they should. LIM is ready to go on. Can't wait to get this done.
  10. #10 Re: Won't start after cam install
    wait...what did we find? how do we know it's going to run now?
  11. #11 Re: Won't start after cam install
    The cam/crank timing is fine. The valves and pistons never contacted each other. The harmonic balancer problem (a serious ignition timing problem) is the only possible thing that could have caused this... I think.
  12. #12 Re: Won't start after cam install
    swift current,sask.
    Sometimes the air likes to push the piston down.
  13. #13 Re: Won't start after cam install
    Yea. The piston has to be at the perfect spot. If it doesn't work, I'll use rope.
  14. #14 Re: Won't start after cam install
    The anticipation is killing me!!!
  15. #15 Re: Won't start after cam install
    Almost!!! Oil and coolant about to go in
  16. #16 Re: Won't start after cam install
    X2 !
    lets get the vid going too.
  17. #17 Re: Won't start after cam install
    It's making the same ****ing noise. OMFG. It ran okay for about 10 seconds, then all of a sudden, loud ****ing tapping. F*CK. Ughhhhhhhhhhhhhh.
  18. #18 Re: Won't start after cam install
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    damn, that sucks.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  19. #19 Re: Won't start after cam install
    The pushrods are probably ****ed again. OMFG. What the ****!!!
  20. #20 Re: Won't start after cam install
    Donating Users
    South Deerfield, MA
    If the valve seals were smashed, then that means the rocker is smashing the retainer all the way to the bottom, right? Thinking that through would mean the cam is higher lift than you think it is, the lifter is longer than it should be, the pushrod is longer than it should be or the ratio of the rocker is higher. I can't think of any other way this could happen. Any chance one of those parts are not the right ones?
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  1. how hard is it to install an alarm with remote start
    By nascartech in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2010, 05:55 PM
  2. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
  3. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  4. Remote Start Install Questions...
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 02:19 PM
  5. car rattles after cam install then wont start at all!
    By chrisb in forum General Tech Discussion
    Last Post: 07-11-2008, 10:54 AM
