Thread: Won't start after cam install
Results 1 to 20 of 448
  1. #1 Re: Won't start after cam install
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    Good luck!
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  2. #2 Re: Won't start after cam install
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Some of the valve seals are wrecked, so I'm going to replace those. However, I don't have the spark plug air adapter so I won't be able to get it running until tomorrow at the earliest. Always something.
  3. #3 Re: Won't start after cam install
    swift current,sask.
    Quote Originally Posted by Bedwards View Post
    Worst case, use some para cord in the spark plug hole. Just get it to the bottom of the intake stroke or whatever, jam as much rope in there as possible and hand turn it to the compression stroke until it gets hard to turn. and take the spring off. I don't like air, you drop that valve somehow you are screwed.
  4. #4 Re: Won't start after cam install
    Quote Originally Posted by whiney View Post
    The valve won't drop if the piston is at TDC.
  5. #5 Re: Won't start after cam install
    Changed all the valve seals. Got the rest of the valvetrain (pushrods, rockers etc.) assembled and torqued. I turned my motor over by hand and it is turning over WAY easier than before. No binding or strange sounds. All the valves are opening how they should. LIM is ready to go on. Can't wait to get this done.
  1. how hard is it to install an alarm with remote start
    By nascartech in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2010, 05:55 PM
  2. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
  3. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  4. Remote Start Install Questions...
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 02:19 PM
  5. car rattles after cam install then wont start at all!
    By chrisb in forum General Tech Discussion
    Last Post: 07-11-2008, 10:54 AM
