Thread: Won't start after cam install
Results 1 to 20 of 448
  1. #1 Re: Won't start after cam install
    Donating Users
    South Deerfield, MA
    If the valve seals were smashed, then that means the rocker is smashing the retainer all the way to the bottom, right? Thinking that through would mean the cam is higher lift than you think it is, the lifter is longer than it should be, the pushrod is longer than it should be or the ratio of the rocker is higher. I can't think of any other way this could happen. Any chance one of those parts are not the right ones?
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  2. #2 Re: Won't start after cam install
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Quote Originally Posted by Silver GTP View Post
    If the camshaft that I was sent was wrong... Then yes. But I was told that this is a VS cam, he told me positively...
    The rockers are stock.
    Pushrods are stock.
    Lifters are stock (and are now LS7 lifters).
    G8 valve springs/retainers.
  3. #3 Re: Won't start after cam install
    Donating Users
    South Deerfield, MA
    Quote Originally Posted by Bedwards View Post
    Pushrods are stock.
    Since you have to pull it apart anyway, I would start by double checking the engraving on the end of the cam. I don't know if ZZP engraves the name on the end of the cam or just a number of some type. You may have to check with them to verify which cam it is. If it really is a VS cam, you should have plenty of clearance unless you had a massive brain fart and forgot to put the tray in under the rockers. I see you have the SSM90 set up too. Since you have the naturally aspirated heads, are there any differences between yours and the L67 heads that could cause a clearance issue like this?
  4. #4 Re: Won't start after cam install
    You bring up some good points. I wish I saw what the engraving on the cam was. The tray is under the rockers. I'm not sure if there are different clearances between L67 and L36 heads. Someone should know. I think we are onto something with the too much lift scenario. The valve seals were all smashed.
  5. #5 Re: Won't start after cam install
    Would stronger springs solve this? If that was the problem.
  6. #6 Re: Won't start after cam install
    Donating Users
    South Deerfield, MA
    No. A problem from the wrong springs would be coil binding. If your setup is driving the retainer down into the valve seal, it is a matter of clearance. Modified retainers would give some extra clearance to the valve seal. As bad as the pushrods got destroyed, I think you might need more than that to fix your problem.
  7. #7 Re: Won't start after cam install
    I will lose my mind of I got sent the wrong cam.
  1. how hard is it to install an alarm with remote start
    By nascartech in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2010, 05:55 PM
  2. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
  3. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  4. Remote Start Install Questions...
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 02:19 PM
  5. car rattles after cam install then wont start at all!
    By chrisb in forum General Tech Discussion
    Last Post: 07-11-2008, 10:54 AM
