Thread: Won't start after cam install
Page 6 of 23 FirstFirst ... 4567816 ... LastLast
Results 101 to 120 of 448
  1. #101 Re: Won't start after cam install
    you can whack at it all you want to get it to move, but a puller should have done the job.
  2. #102 Re: Won't start after cam install
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Did a compression test. Mind you, the motor was cold (obviously):
    Cylinder 1 - 90
    Cylinder 2 - 120
    Cylinder 3 - 80
    Cylinder 4 - 110
    Cylinder 5 - 115
    Cylinder 6 - 120
  3. #103 Re: Won't start after cam install
    The puller is failing miserably. Won't even move it.
  4. #104 Re: Won't start after cam install
    Ummm...front banks a little low....?
  5. #105 Re: Won't start after cam install
    Everything looks a little low. I'm thinking you didn't block the throttle or something. Not sure if I believe the compression test.
    As for the balancer. That's where I'd concentrate now. Something is very wrong if the bolt is out of it and it's not coming off.
  6. #106 Re: Won't start after cam install
    Is there anyway I could have overtightened the pulley and messed up the alignment of the crank?
  7. #107 Re: Won't start after cam install
    Remember how I said the other night that I get the keyway to engage by pushing and turning until it seats. What I left out is once it seats... I hit the bolt with my airgun. It's a 1/2" Ingersold Rand gun with 500 forward ft lbs of torque. Reverse is 600.
    When that bolt stops moving..it's at spec.
  8. #108 Re: Won't start after cam install
    Something is preventing it from turning. Something is binding. Could the pulley make tht kind of an issue?
  9. #109 Re: Won't start after cam install
    Something is preventing what from turning.?
    Concentrate your efforts on getting that Harmonic Balancer off. Something is wrong there and likely that's your no start problem
  10. #110 Re: Won't start after cam install
    The motor isn't turning properly. Way too much resistance. I'll work on the balancer.
  11. #111 Re: Won't start after cam install
    I'm buying a Snap On puller. I have an idea to try get it off. I'm gonna use some heat from a heat gun (around the pulley), and also put a drilled metal block on the front of the puller. I'll tap the metal block with the same size threads as the puller, so I have more thread engagement, and more torque to pull with. I don't want to strip the tool this time.
  12. #112 Re: Won't start after cam install
    Delaware, OH
    You'll need a torch if you're wanting heat. Heat gun won't phase it.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  13. #113 Re: Won't start after cam install
    heat the balancer with the torch, not the crank, and when you have tension on the puller like it feels like it wont move, tap the balancer,, work the puller tap the balancer and so on, hopefully that will let it pop forward, little by little.
  14. #114 Re: Won't start after cam install
    Heat the front of the pulley? Like around the shaft? Or the side of the pulley (where the belt runs)?
  15. #115 Re: Won't start after cam install
    heat the front of the balancer around the crank, but try not to heat the crank, you want the balancer to expand.
  16. #116 Re: Won't start after cam install
    Denver
    Doesn't the harmonigc balancer have a rubber insert in it (for damping purposes)? If so, get ready to replace your balancer it you put a rosebud to it....
  17. #117 Re: Won't start after cam install
    im thinking the balancer's toast already, it wont come off. and it needs to.
  18. #118 Re: Won't start after cam install
    Got the Snap On puller. This thing is heavy duty. I work tonight, so I won't be able to get a start on trying to get the thing off until tomorrow morning.
  19. #119 Re: Won't start after cam install
    Nov 2010
    Atlanta Ga
    Please do not use a hammer! Your crank thrust bearings will take all the abuse.
  20. #120 Re: Won't start after cam install
    The Snap On puller got it off no problem. I'm gonna pull the front cover and check the timing.
  1. how hard is it to install an alarm with remote start
    By nascartech in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2010, 05:55 PM
  2. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
  3. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  4. Remote Start Install Questions...
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 02:19 PM
  5. car rattles after cam install then wont start at all!
    By chrisb in forum General Tech Discussion
    Last Post: 07-11-2008, 10:54 AM
