Thread: Won't start after cam install
Page 3 of 19 FirstFirst 1234513 ... LastLast
Results 41 to 60 of 448
  1. #1 Re: Won't start after cam install
    One tooth off won't make a difference for starting.
    One suggestion I make to everyone is take pictures of teh gears and dots. Always. That way you never question yourself if something goes wrong.
    Gotta go back and reread the thread to see what you've tried so far.
  2. #2 Re: Won't start after cam install
    Ok, let's see. Assume your timing is ok on the gear unless it turns to a point a binds. Binding would be bad.
    Check for spark, got that ...good.
    Take a piece of vacuum line and run it off the metal nipple under the SC on the LIM. Put the straw of a can of brake cleaner in there and have someone crank the car.. do a few short bursts of brake clean. Does it run? Does your shooting brake clean help it start? If yes..check the maf. a bad maf can turn off the injectors.
    Crank sensor is plugged in? Pull the connector and inspect with a mirror for any bent pins. Check the ICM connector. Should be snug.
  3. #3 Re: Won't start after cam install
    if you have fuel and spark, does it have air?
  4. #4 Re: Won't start after cam install
    Cam postion sensor could be the cause. If it's unhooked you have a 1 in 6 chance the motor will start. However I've never seen one cause it to run badly like you mentioned.
  5. #5 Re: Won't start after cam install
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    There's no vacuum leaks that I can see.
  6. #6 Re: Won't start after cam install
    You'd have to have something like the EGR tube off (if not blocked) or the brake booster for that big of an issue.
  7. #7 Re: Won't start after cam install
    Donating Users alkygto's Avatar
    Nov 2009
    wentzville
    Seriously, some good help here. Glad to see it.
    1997 Pontiac Grand Prix GTP
    1969 Pontiac GTO
  8. #8 Re: Won't start after cam install
    I'm going to replace the ICM harness tomorrow and see if that does anything.
  9. #9 Re: Won't start after cam install
    Just wondering, if a MAF sensor got wet, could it cause a no-start issue?
  10. #10 Re: Won't start after cam install
    GT Level Member Tea Time's Avatar
    New Brunswick
    i wouldn't think so...unplug it and see if the car runs...it'll run poor for a minute unplugged but will come out of it.
    '00 GTP - Summer Toy
    '97 GTP - Project
    '99 GT - Gone (Frame Rotted)
    '98 SE - Gone (Parts Car)
  11. #11 Re: Won't start after cam install
    Delaware, OH
    Just a though but have you unplugged the MAF and tried starting it? It'll switch over to speed density tables if no maf is showing. Won't run as good but it'll still run.
    Also I've seen some pretty stupid **** happen like a rag being left in the intake and plugging it.
    Edit. Tea time beat me to it.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  12. #12 Re: Won't start after cam install
    I'm not home tonight. I'll try unplug the MAF and try start it tomorrow. I'm sure I didn't leave anything in the motor when I put it together.
  13. #13 Re: Won't start after cam install
    New Brunswick
    did u gave that battery a good charge yet?...or is the motor that hard to turn over that it creates resistance when starting?..like the guys stated before, the battery sounds weak (via ur videos), but i'm wondering if the battery is good and the engine is binding a bit.
    '97 GTP - Project
  14. #14 Re: Won't start after cam install
    Quote Originally Posted by Tea Time View Post
    Battery is fully charged according to my multimeter. It does feel like it's binding a bit.
  15. #15 Re: Won't start after cam install
    from the earlier posts it seems that its not turning over by hand to easily either, that would be where id be concentrating on for now, the harness seem to be in the wrong direction to me.
    maybe pull the plug wires and try to crank it, see it cranks any easier. still seems to be timing related to me, but we're not there to play with it.
  16. #16 Re: Won't start after cam install
    New Brunswick
    Scotty, how would pulling the plug wires help it turn over easier?...u mean pull the plugs, then turn over?
    '97 GTP - Project
  17. #17 Re: Won't start after cam install
    Delaware, OH
    What's the line that I circled?
    Also it almost sounds like it's firing but at the wrong times. Is it possible you've hooked the injectors up incorrectly to the wrong connector? Looks like you've rearranged the wiring harness so that's a possibility.
    No More GTP for me.
  18. #18 Re: Won't start after cam install
    Quote Originally Posted by benner View Post
    Thats my EVAP line. The injector wires are only long enough to reach the specific cylinder they are meant for. Couldn't have mixed them up.
  19. #19 Re: Won't start after cam install
    Delaware, OH
    Ok, wasn't sure if you stripped the harness apart to move stuff around or not.
    This is driving me nuts as well. It's probably something simple and stupid that we're all missing.
    No More GTP for me.
  20. #20 Re: Won't start after cam install
    What would cause a higher than normal resistance when cranking? Is tIming the only thing?
  1. how hard is it to install an alarm with remote start
    By nascartech in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2010, 05:55 PM
  2. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
  3. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  4. Remote Start Install Questions...
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 02:19 PM
  5. car rattles after cam install then wont start at all!
    By chrisb in forum General Tech Discussion
    Last Post: 07-11-2008, 10:54 AM
