Re: Won't start after cam install
If you where in the states I would mail ya a couple, I found them in my coat pocket from my first build lol.
TheOtherNick
Lol. Awe crap. Thanks though man.
Found the stupid thing! Haha. I will have this done this afternoon!
Got it all back together. But my battery needs charging. It's dead as a door nail. I'll let that charge for a while.
One question. Does anyone know what the clearance should be between the valve spring retainer and the valve seal on LS springs? I'm maybe sitting around 0.030" right now.
God dammit man....take the battery out of ur parent's car! :th_king-evil::th_nanana: ....lol
we're all waiting on this :th_thumbsup-wink:
Tea Time
Hahahahaha.
Way to add suspense to the thread! lol
Bedwards
should be more than that. your cam is in the .400s for lift.
TheOtherNick
Isn't the lift with the VS cam 0.507 and 0.512?
might be but think about it if you have .03 till the retainer hits the seal and your rocker moves .5.
TheOtherNick
A guy from PRJ says anything over 0.010" is fine. Hmmm.
hmm i must be off on my thinking tonight.
You talking valve open or closed?
TheOtherNick
Open.
Ok yeah thats fine then, I thought you where talkin valve closed. Go start that Biznitch
WOOOOOOOO!!!!!!!!!
97e4fe58.mp4 video by Bedwards923 - Photobucket
Thank you everyone!!! So much!!!!
Every few seconds, I kind of get a deep popping noise, sounds like exhaust. The idle rpm is moving from around 750 to 850, AFR from 14.9 to 16.9, and the boost gauge jumps around 4 psi. Maybe a vacuum leak?
awesome!, congrats.
now go enjoy it.
Bedwards
try the carb cleaner spray test around the engine yet to see if it has a vac leak.
I think I figured out the vacuum leak problem. I took it for a drive, and at like 30 km/hr, I heard a metallic clank sound, and it jerked. I think it's my CV joint though. When I pulled the motor, the transmission came up a bit too, and stressed it really bad. It's leaking green grease, so hopefully that's my issue here now.
Could an axle be bad enough that it momentarily clunks and slows the car down?
