Thread: Won't start after cam install
Results 1 to 20 of 448
Threaded View
  1. #10 Re: Won't start after cam install
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    The plug wires are for sure correct. Triple checked them. All the connectors are plugged in. All the ignition fuses are good. The grounds all appear to be connected. I never touched the starter wires when I pulled my motor, I just unbolted it from the block. The battery is reading 12.78 volts without the key in the ignition. I haven't checked for spark yet, as I'm the only one home and I don't have anyone to crank the engine for me.
    I did notice something though... The clip holding the camshaft position sensor broke off, but I can't tell if the connector is still pushed in all the way. The grey rubber grommet around it is sticking out a bit, is that normal? Here's a picture:
  1. how hard is it to install an alarm with remote start
    By nascartech in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2010, 05:55 PM
  2. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
  3. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  4. Remote Start Install Questions...
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 02:19 PM
  5. car rattles after cam install then wont start at all!
    By chrisb in forum General Tech Discussion
    Last Post: 07-11-2008, 10:54 AM
