How should the spark numbers look like? I do drop timing to prevent knock. I first tried adding fuel to see if it went away, but it never did, no matter how much fuel I added. The O2s won't go up either (narrowband of course). So I had to start dropping timing at the end of the curve.
Would it be better if the timing was all around the same numbers even if it was in the 16s?
By the way, it really doesn't feel like it drops when I hit the lower numbers, it actually feels quite steady right now.
Oh and I don't have injectors yet either. I think the limit will be the injectors here.
