Thread: pulley size?
Results 1 to 20 of 36
  1. #1 pulley size?
    SE Level Member bensett004's Avatar
    michigan
    just currious what the stock pulley size is on a 99 gtp? ive read up on everything and im still unclear and was wondering what the ideal pulley size would be for me to drop to? got autolite 104's plog, 3in catless dp, kn cone filter with 3.5 in pipe ran as far as i could with no bends, i know i need a tune i think i have one already but i want to buy a pulley so im ready for scan and tune asap thanks....
    fwi, kn filter, 3 in down pipe, power log, 180* thermostat, 10000k hids and soon to come a dhp pcm
  2. #2 Re: pulley size?
    Willoughby, Ohio
    3.8" is stock pulley size. after a tune buy a modular pully system and you can maybe get away with a 3.6" pulley until you get rockers and perhaps some porting for a 3.4"
  3. #3 Re: pulley size?
    michigan
    thats what i was lookin for i dont plan to get to crazy, its already fast what kind of a difference would i fell with a 3.6?
  4. #4 Re: pulley size?
    Willoughby, Ohio
    if i were you, i would just get all the requirements for the 3.4" setup, if you think its fast now then you will love the power you will have after
  5. #5 Re: pulley size?
    michigan
    and another thing i was just looking on zzperformance web site and i said u could run a 3.5 on stock car? that dont seem right does it?
  6. #6 Re: pulley size?
    michigan
  7. #7 Re: pulley size?
    Charles City, IA
    You can, is it good for it not really, will it blow it up probably not, do you get more power, no, Just some low end until the pcm starts pulling timing.
    SMGPFC Two Nipple General
  8. #8 Re: pulley size?
    Willoughby, Ohio
    i wouldnt drop pulley sizes till at least get flow mods on, and my goal would be the 3.4" setup just beczuse its like the fist goal to reach as far as modding goes
  9. #9 Re: pulley size?
    michigan
    dont i already have flow mods?
  10. #10 Re: pulley size?
    GTX Level Member colindunn's Avatar
    Aurora, IL
    i want to do a 3.6 pulley. mostly because i dont wanna burn up my tranny and i dont have the money right now for all the extra mods. my only problem is that the only pulley upgrades i see are 3.5 or lower. where could i get a 3.6? anybody know how much power i would gain with a 3.6 setup with supporting mods and a tune?
  11. #11 Re: pulley size?
    Quote Originally Posted by bensett004 View Post
    you do but, not enough. Just sell you plog and get headers, then you will be set.
  12. #12 Re: pulley size?
    michigan
    i see....so i couldnt tune out of kr? even with the plog? jw is it a big dif goin from stock to 3.4?
  13. #13 Re: pulley size?
    SE Level Member RideMr2's Avatar
    Memphis
    Quote Originally Posted by colindunn View Post
    Look at pfyc.com, check out the pulley boys quick change system. You can get a 3.8" pulley if you like.
    Qwikchange Supercharger Pulley System - Under the Hood
  14. #14 Re: pulley size?
    Charles City, IA
    Yes you can tune kr out. Timing>boost. Less boost more timing = win.
  15. #15 Re: pulley size?
    Apr 2009
    stockton ca
    There is a deffinate diff in the stock 3.8 and 3.4 your flow mods are fine for a 3.4 set up just not beyond that
    as long as you have 104 plugs 180 tstat and tune your pretty much fine I would scan for kr after though just to make sure
  16. #16 Re: pulley size?
    why do you guys care about how much power you get from a different pulley?
    I'm willing to bet I could make more power on a 3.8" pulley than you could on a 3.4 or 3.6.
    All depends on what mods you have with it and the engine itself.
  17. #17 Re: pulley size?
    michigan
    idk about that.....more boost=more power, smaller pulley more boost.....
  18. #18 Re: pulley size?
    ...since when? you dont know enough on the subject if that is your thought process. to a certain extent you are correct, but a car that is running more timing will not only 'feel' faster, but usually will be faster.
    fueling > timing > boost
    boost is the last thing you add to the system when you tune.
  19. #19 Re: pulley size?
    michigan
    read what he said......i can make more power off a stock pulley didnt think it was possible, lets not get our pantys bunched up
  20. #20 Re: pulley size?
    michigan
    lets not jump all over me about it when i was just giving the jist of it and read everything before u call me out
  1. help with pulley size?
    By benblank in forum 04+ Specifics
    Last Post: 03-19-2010, 12:24 AM
  2. need some help with pulley size
    By mack1212 in forum General Tech Discussion
    Last Post: 04-01-2009, 08:11 AM
  3. To Pulley or not to Pulley is not the question.... SIZE IS
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2009, 10:43 AM
  4. What size pulley and what size belt??
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 08:55 AM
  5. pulley size=hp?
    By underpressure2004 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2008, 11:03 PM
