So on my 98 GTP, my buddy and I did the lower intake gaskets today and we replaced all the gaskets along with the T-start and we cleaned the throttle body. We put it back together and everything went slow but okay the only thing we really ran into is that there is this black piece ontop of the supercharger thats circular that has 3 nipples coming out of it and one of them broke off. We couldn't get it back together and my buddy thinks its a vaccum of some sort. We followed the line it ran to the passenger side wheel well and then ended right below the fuse Box and we have no idea where it could go, or do. So we started it up everything connected and in place we had the bad line taped just for a temporarly fix and it started , sounded like it had a a cam we cut the engine did it again and it knocked a little, not like a true knock but a light ticking noise so we pluggged up the bad line right at the start of it and started it again and same thing. So any ideas what this could be?
Thank you in advnaced, I know this is long and thank you for reading this if you did, I just really need to get my car running back to normal.
