Thread: S/c oil change
Results 1 to 20 of 27
  1. #1 S/c oil change
    I just changed my oil in my supercharger and i'm pretty sure it's never been changed and the car has 193,000 on it lol. I brought the old oil in the house to show my wife and all she could say was it stinks get it away. It looked like very thick very dark brown "substance". The sc oil i put in was clear lol.
    btw summit racing rocks. I called the local gm dealership and it was $17 a bottle i got two bottles shipped to my door for $25. I ordered it last night at 8pm and received it today at 6pm that's what i call service lol
  2. #2 Re: S/c oil change
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    good deal
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  3. #3 Re: S/c oil change
    yup its smells.
    not to be completely of topic here, but are you really using a 160 thermostat in your stock gtp??? If so thats not very good for the car at all.
  4. #4 Re: S/c oil change
    Yeah i have a 160 thermo that's what came in it. I plan on other upgrades when i get the chance. I don't see as to how it would hurt the motor at all running cooler.
  5. #5 Re: S/c oil change
    160* is too cold. Get a Stock replacement or a 180*.
  6. #6 Re: S/c oil change
    Why is it to cold? What problems would it cause?
  7. #7 Re: S/c oil change
    running the motor colder than it is supposed to be ran accelerates wear on the motor and decreases mileage. there is absolutely no reason for you to run a 160* thermostat, nor a 180* thermostat. go buy a stock 195* thermostat and put that in and be happy.
    running the motor colder is an old school trick that is no longer relevant within the technology we are offered today.
  8. #8 Re: S/c oil change
    I'm just assuming it's a 160 because the temp gauge only get to just between the 100 and 210 on the gauge. I don't see how it would cause any excess wear on anything because don't most stuff break because of excess heat? I can understand the mileage decrease but that should be minimal. Right?
  9. #9 Re: S/c oil change
    Ocala, FL
    Look again. Its between 160 and 210, not 100 and 210. That means your temps are around normal stock temps, you have a stock tstat.
  10. #10 Re: S/c oil change
    Quote Originally Posted by codyAK View Post
    I just looked and it's 100 at the bottom. My buddies 99 gt says 160 at the bottom.
  11. #11 Re: S/c oil change
    If it going halfway up gauge...it is a normal temp t-stat...no matter what the lowest temp reading says.
  12. #12 Re: S/c oil change
    unless his fans are set lower it shouldn matter really that much...
  13. #13 Re: S/c oil change
    When cruising on the highway it will drop as if it was tuned for it though...I had a 180* before I got a canned tune...
  14. #14 Re: S/c oil change
    ah ya i suppose thats true
  15. #15 Re: S/c oil change
    Ocala, FL
    You must have a 97.. I think the cluster in those was different than 98-02, and 03..
    Regardless, if you are running between the two tickers, you are at normal temps.
  16. #16 Re: S/c oil change
    i have a 98 and it hits just around the mark between the 100 and 210.
  17. #17 Re: S/c oil change
    SWPA
    The colder theremostat is definitely a bad thing. The problem is the ECU can never get to normal operating temp and will continue to dump too much fuel. This causes carbon buildups and excess wear.
    Too cold is just as bad as too hot.
  18. #18 Re: S/c oil change
    Waukesha, WI
    wasnt it only 97s that the gauge started at 100?
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  19. #19 Re: S/c oil change
    pennsylvania
    i have question what kind of supercharger oil should i get and where?
  20. #20 Re: S/c oil change
    Charles City, IA
    Gm supercharger oil from the dealer.
    SMGPFC Two Nipple General
  1. Change oil at what %?
    By shawnz90 in forum General Tech Discussion
    Last Post: 07-25-2011, 09:04 AM
  2. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
  3. anyone ever change a gt to a gtp
    By e56505 in forum General Tech Discussion
    Last Post: 02-18-2009, 12:12 AM
  4. How soon do you change the oil after........
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-17-2009, 03:56 PM
  5. s/c oil change
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-10-2008, 05:44 PM
