Thread: sputtering under load
Results 1 to 4 of 4
  1. #1 sputtering under load
    ATX
    So about 2 or 3 weeks ago there was a mistake and about 1.5 gallons of 87 got put in my car, Topped it off with 20 bucks of 93 and put some STP octaine booster in, started driving, and under heavy load with no boost like going up a hill it was sputtering and backfired once..
    Babyed it around and burned off half the tank, still sputtering under heavy load like trying to go from 60-65mph it would just loose all power and id have to back off the gas and then give it a little bit more throttle and it would go.
    Iv used up all the gas, put a fresh tank of 93 in, changed the fuel filter and cleaned the maf.
    Its still doing it.. Im thinking the cats stuffed up. I drove it around tonight to get it hot and checked if it was glowing.. it wasnt a light blob but it was a little discolored and there was a spot on it blacker then sin, right where it connects to the downpipe.
    Cars stock with a ported blower and CAI.
    Thoughts?
  2. #2 Re: sputtering under load
    St. Louis
    Can you not get the car above a certain RPM range? Usually this is a sign of a clogged cat. If you suspect this, try dropping the exhaust loose and see if that changes anything. It will be louder than you know what, but for a short test drive you could get away with it.
  3. #3 Re: sputtering under load
    Vancouver, WA
    I had the same issue when I had bad plugs
    Slowest 'Cooled Gen V ever
  4. #4 Re: sputtering under load
    ATX
    Quote Originally Posted by footballplaya3k View Post
    got brand new plugs and wires (well about 1k miles) but yeah.
    I have to put maybe half throttle to get it to go over like 3k rpms i think?
    I feel like somethings choking the motor..
  1. GTP sputtering, misfireing under load
    By LSXHP in forum General Tech Discussion
    Last Post: 10-23-2012, 04:31 PM
  2. gtp sputtering
    By ecflattracker in forum General Tech Discussion
    Last Post: 03-12-2010, 11:15 AM
  3. sputtering
    By duneking905 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2010, 02:25 AM
  4. gtp missing under load
    By jshuman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-20-2010, 01:12 AM
  5. help. car sputtering at wot.
    By 1gtp99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2009, 05:15 PM
