Thread: Cam install. Can't get crank bold off.. any help?
Results 1 to 20 of 23
  1. #1 Re: Cam install. Can't get crank bold off.. any help?
    Donating Users Brooks's Avatar
    Nov 2009
    baltimore, md
    Wow thanks for all the responses.
    Its a 26 gallon tank, 5.5peak hp 1.7 maint with 150psi max. The hose is 9mm 3/8'' hooked up to a husky 275maxpsi impac gun. I hammered it for a good while with no success.
    I believe I actually tried that breaker method, I just cowered out after hearing some undesireable noises. I felt like I was going to break something if I racked it foreward much harder. Perhaps I should have just used my man hands and gone through with it. It's all back together now so I will have to try it for another day.
    Gen V 98 Regal GS
    Baltimore, MD
  2. #2 Re: Cam install. Can't get crank bold off.. any help?
    Minnesota
    Quote Originally Posted by Brooks View Post
    The compressor sounds right but the impact is way too weak to do the job because I assume you meant 275ft/lbs. If you can barrow or rent a better impact I bet it would come right off. I had a hard time with my Ingersol Rand rated at 600ft/lbs.
    By Leon in forum General Tech Discussion
    Last Post: 02-02-2011, 08:24 PM
  2. Crank key
    By Enzo354 in forum General Tech Discussion
    Last Post: 10-26-2010, 03:45 PM
  3. Car Won't Crank..Again
    By brandonl2000 in forum General Tech Discussion
    Last Post: 07-30-2010, 12:58 PM
  4. For Sale HTC HD 2 Unlocked 300$...Blackberry Bold 9700...300$
    By king1234 in forum Introductions/Noob Questions
    Last Post: 11-10-2009, 12:51 PM
