Thread: Cam install. Can't get crank bold off.. any help?
Results 1 to 20 of 23
  1. #1 Re: Cam install. Can't get crank bold off.. any help?
    Donating Users Brooks's Avatar
    Nov 2009
    baltimore, md
    Its all back together now, I was just showing silver gtp what I tried because I'm pretty sure its the same he was describing.
    Gen V 98 Regal GS
    Baltimore, MD
  2. #2 Re: Cam install. Can't get crank bold off.. any help?
    Donating Users
    South Deerfield, MA
    Quote Originally Posted by Brooks View Post
    Yep, that's exactly how I did mine. Had to push pretty hard on that pipe to get it to break loose. If you block the flywheel from turning and use the same method, it should come off. Make sure you are pushing on the pipe and not pulling. We all have brain farts once in a while. It will be kinda rough at first. The whole back side of the head is coated with a red thread locker to stop the bolt from coming loose. It makes a little noise as you break that stuff free.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  3. #3 Re: Cam install. Can't get crank bold off.. any help?
    Wichita, KS
    ^The back side of the bolt head is coated with orange-ish red RTV from the factory to keep the engine oil from coming out around the bolt. If you don't install RTV, then it will fling oil as you drive.
    ~F~
  4. #4 Re: Cam install. Can't get crank bold off.. any help?
    Feb 2008
    Quote Originally Posted by GR8racingfool View Post
    ~F~
    YUP! Found that out the hard way after my buddy removed the "orange gooey sh*t" and re-used the factory bolt one time. Had to pull it all back apart, replace the crank seal, and put on a new bolt.
    24" breaker bar + 36" cheater pipe = easy work on a difficult bolt!
    (The hood was off at the time, so I actually had room to use all 5-feet...)
  5. #5 Re: Cam install. Can't get crank bold off.. any help?
    Mercer, Pa
    Put some WD40 in the impact gun, makes the impact hit a little harder for a short period of time.
  6. #6 Re: Cam install. Can't get crank bold off.. any help?
    Nov 2009
    baltimore, md
    Quote Originally Posted by Silver GTP View Post
    I have an engineering background not auto mechanics so excuse me if my questions are trivial.
    How do I block the flywheel from turning, will I be disassembling the transmission?
    Gen V 98 Regal GS
    Baltimore, MD
  7. #7 Re: Cam install. Can't get crank bold off.. any help?
    Banned
    Sioux Falls, SD
    Take ur starter off and direct access to flywheel
  8. #8 Re: Cam install. Can't get crank bold off.. any help?
    Quote Originally Posted by miker56 View Post
    time out! why are we taking the starter off? you can get at the flex plate by taking off a couple plastic inspection covers under the car. it's just that easy.
    then put a vice grips on the flex plate and it wont move past the notches that it catches on.
  9. #9 Re: Cam install. Can't get crank bold off.. any help?
    Banned
    Sioux Falls, SD
    Sorry forgot about the inspection plate!! thanks bio
  10. #10 Re: Cam install. Can't get crank bold off.. any help?
    Donating Users
    South Deerfield, MA
    Yep, exactly how I got in there. Right at the bottom of the transmission where it meets the oil pan is a small, black plastic cover held on by two bolts. If you take that off, you will see the bottom of the flywheel. I had a pry bar that matched up to the shape of teeth really well and used that to hold it in place while breaking the bolt.
    Don't worry about asking questions that you think are trivial. I wasn't born knowing everything about cars and never will, but what I do know I had to learn somewhere along the way. The more you learn, the less questions you need to ask.
    By Leon in forum General Tech Discussion
    Last Post: 02-02-2011, 08:24 PM
  2. Crank key
    By Enzo354 in forum General Tech Discussion
    Last Post: 10-26-2010, 03:45 PM
  3. Car Won't Crank..Again
    By brandonl2000 in forum General Tech Discussion
    Last Post: 07-30-2010, 12:58 PM
  4. For Sale HTC HD 2 Unlocked 300$...Blackberry Bold 9700...300$
    By king1234 in forum Introductions/Noob Questions
    Last Post: 11-10-2009, 12:51 PM
