Yep, exactly how I got in there. Right at the bottom of the transmission where it meets the oil pan is a small, black plastic cover held on by two bolts. If you take that off, you will see the bottom of the flywheel. I had a pry bar that matched up to the shape of teeth really well and used that to hold it in place while breaking the bolt.
Don't worry about asking questions that you think are trivial. I wasn't born knowing everything about cars and never will, but what I do know I had to learn somewhere along the way. The more you learn, the less questions you need to ask.
