Thread: Engine noise Supercharger??
Results 1 to 8 of 8
  1. #1 Engine noise Supercharger??
    SE Level Member drewz313's Avatar
    Morgantown, wv
    Does anybody know how to check the bearings in a supercharger? I originally thought it was a lifter or a push rod. I am not to sure now since I pulled off the S/C and the intake. Everything looks good. The engine developed a loud tapping like a pulley was going bad. I took all the belts off and still had the noise so I ruled out the S/C but I am not really sure. Anybody help would be greatly apprieciated.
  2. #2 Re: Engine noise Supercharger??
    Charles City, IA
    If you pulled the supercharger belt off and the noise was still there it is not the supercharger. It could be a lifter not pumping up.
    SMGPFC Two Nipple General
  3. #3 Re: Engine noise Supercharger??
    Morgantown, wv
    That was what I was thinking also. But when I turn the supercharger by hand I can hear a sound similar to the noise it was making. The blower would still be turning even with the belt off from the air going through the throttle body and into the intake. Right?
  4. #4 Re: Engine noise Supercharger??
    Donating Users mystic231's Avatar
    Michigan
    I had a ticking noise on my GT I assumed was a stuck lifter so I drained a quart of oil out and replaced it with a quart of Marvel Mystery Oil and it cured it.
    Edit:
    Was the pulley on the S/C turning? I don't think so. It takes more HP to turn the blower than just air flowing through it. That's what the BBV is for.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  5. #5 Re: Engine noise Supercharger??
    GT Level Member Will5600's Avatar
    subs of chicago
    dose the noise go away after the engine heats up bc i have an exhaust leak but it goes away
  6. #6 Re: Engine noise Supercharger??
    Morgantown, wv
    the noise is there no matter if it is hot or cold. I tore the supercharger apart and I think I have a bearing going bad. The snout bearings are good. The housing of the blower has some wear in it where it looks like the screws of the blower were rubbing it. I am going with new lifters and push rods and a supercharger rebuild. Does anybody have pictures of stock Rocker arms? I think whoever owned this car put aftermarket ones on. I am not really sure.
  7. #7 Re: Engine noise Supercharger??
    Stockers: L67 rockers image by thomasjman on Photobucket
    Aftermarketers: http://www.3800performance.com/Merch...ocker_arms.gif
    OR...cool colored Harland Sharp Rockers seen here in a I6 Jeep: http://jeep.blackonyx.net/forum/hsrr/3.jpg
  8. #8 Re: Engine noise Supercharger??
    Morgantown, wv
    Thanks. They are stock for sure.
  1. SuperCharger Noise
    By Bubweiser21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-22-2012, 11:47 PM
  2. Supercharger Noise
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2009, 03:45 PM
  3. Noise in the supercharger
    By xawahl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2009, 06:58 PM
  4. supercharger noise at idle
    By slippyskippy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2009, 08:14 PM
  5. Supercharger noise and questions
    By DMohr87 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2009, 12:11 PM
