Thread: High KR! ?
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21 Re: High KR! ?
    Either that^^, or since it is a '97...I bet the motor mount/trans mount is probably shot and there is something...example...the header DP...making contact with the non-flipped front sway bar...causing false knock.
    Just my idearz
  2. #22 Re: High KR! ?
    Feb 2009
    flintnasty MI
    Quote Originally Posted by Reptile View Post
    Fwiw the car will make some fuel adjustments for the temperature change. I depends on what the IAT sensor sees before the throttle body. This was a reason I tried the modified sensors a few years ago and people thought I was crazy.
    See what your timing is during the knock. Then watch your fuel trims to see how positive or negative they are.
    hahahah
    IAT does nothing for fuel, nothing even pretends to support that theory.
  3. #23 Re: High KR! ?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    hahahah
    Agreed, Unless your talking True Intake air temps and not just the sensor which will then ofcoarse effect actual density. The IAT tables are just a Spark retarding table
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  1. How high should a L67 be able to rev up...
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2010, 06:49 PM
  2. how high can an L67 rev
    By bowtieguy68 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-04-2010, 12:50 AM
  3. High NOX
    By Justin48 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-06-2010, 08:00 AM
  4. How High Is To High?
    By samsquanch in forum General Tech Discussion
    Last Post: 06-17-2009, 12:29 AM
  5. High Flo Cat
    By 04gpking85 in forum General Tech Discussion
    Last Post: 09-15-2008, 01:24 AM
