Thread: how high can an L67 rev
Results 1 to 9 of 9
  1. #1 how high can an L67 rev
    Jul 2010
    missouri
    Im curious. Because my dyno chart reads over 7k but dont make power past 6350
  2. #2 Re: how high can an L67 rev
    unless you have a very large cam where it makes power up there, then there is no point in ever going over 6500 or so. never push the car past where it makes power because youre not helping anything.
    with the right setup, id assume you could push the motor a little over 7000 rpm.
  3. #3 Re: how high can an L67 rev
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    my shift points where set at 6800. The only way your gonna get that high is with a upgraded top end then a cam that can make power
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  4. #4 Re: how high can an L67 rev
    ^^Mod list?
    I'll be shifting at 6500...that's enough.
  5. #5 Re: how high can an L67 rev
    Jul 2010
    missouri
    Thanks. I peak at 6350 but was curious
  6. #6 Re: how high can an L67 rev
    Outer Space
    ^^Mod list?
    I shift around that same range...and still pwning noobs.
    02 GTP 13.6 @ 100mph - SOLD
  7. #7 Re: how high can an L67 rev
    Tulsa, Ok
    ^^Mod list?
    What did i not have done LOL
    2.6" Daily pulley
    ZZP Stage 2 IC
    Machined intake
    CC #105 springs
    CC LS1 Retainers
    CC Pushrods
    CC Lifters
    Diamond pistons .020 over bore
    PRJ Double Roller Timing Chain
    SI vavles
    Intense Stage III cam/heads
    PRJ fuel rails
    Race Tranny w/3.29's
    I had one of the pcm's that zooomer had in his car
    98' GS - Sold
  8. #8 Re: how high can an L67 rev
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Quote Originally Posted by Toofastgs View Post
    2.6" Daily pulley
    ZZP Stage 2 IC
    Machined intake
    CC #105 springs
    CC LS1 Retainers
    CC Pushrods
    CC Lifters
    SI vavles
    PRJ fuel rails
    Jesus. What was your 1/4 mile?
  9. #9 Re: how high can an L67 rev
    CC #105 springs
    Nice list...but for those two things...sorry and sorry.
  1. High NOX
    By Justin48 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-06-2010, 08:00 AM
  2. How High Is To High?
    By samsquanch in forum General Tech Discussion
    Last Post: 06-17-2009, 12:29 AM
  3. Hid with a high beam
    By crywolf in forum Visual/Body Modifications
    Last Post: 01-27-2009, 07:13 PM
  4. High Flo Cat
    By 04gpking85 in forum General Tech Discussion
    Last Post: 09-15-2008, 01:24 AM
