Thread: 3" Downpipe Vibration :th_nervous:
Results 1 to 9 of 9
  1. #1 3" Downpipe Vibration :th_nervous:
    KSteelwheelzJ klj5022's Avatar
    New Carrollton,MD
    I got my DP installed by my mechanic on friday and i noticed the other day that undert intial hard acceleration there is a heavy vibration i can feel under my feet then its gone. I can be launching to WOT and only feel it for like 1.5 seconds or i can be pulling off from a light a little quicker than normal and feel the vibration for about the same amount of time. Any ideas?
    I just wish the police loved my car as much as i do 3.5,160 Stat,HAI,ZZP F/R STB, SSAC Headers, Reptile PCM
  2. #2 Re: 3" Downpipe Vibration :th_nervous:
  3. #3 Re: 3" Downpipe Vibration :th_nervous:
    New Carrollton,MD
    Ho bad s that because i dont have the time or tools to do that and i need my car for work so cant afford to have it in shop again right now
  4. #4 Re: 3" Downpipe Vibration :th_nervous:
    Florida
    Doesnt take much time at all. Less than an hour with a lift.
  5. #5 Re: 3" Downpipe Vibration :th_nervous:
    New Carrollton,MD
    i dont have access to a lift so i would have to pay someone, am i ok without flipping it
  6. #6 Re: 3" Downpipe Vibration :th_nervous:
    Don't get on the throttle hard, it won't hit and you'll be fine. Get it done when you can...then slam the throttle and kill your transmission.
    Oh..it'll be a good idea to save up for that future transmission job.
  7. #7 Re: 3" Downpipe Vibration :th_nervous:
    Oct 2008
    Calgary, Alberta
    I flipped mine without a lift, just a jack and jackstands (orig one was broken, installes gm upgrade flipped) took less than 2 hours, would have been easier on a lift. I had to have the steering wheel turned all the way to one side, and disconnected a tierod end, made sure to keep it in the same orientation so no alignment was required
  8. #8 Re: 3" Downpipe Vibration :th_nervous:
    i flipped mine with the ar on jack stands as well. it is a fairly easy job.
  9. #9 Re: 3" Downpipe Vibration :th_nervous:
    Every W body I've had has needed one. Did em all on jacks. Trick is.. 1 foot or more off the ground.
