Thread: looking at getting the ZZp intercooler need some help.
Results 1 to 20 of 21
  1. #1 looking at getting the ZZp intercooler need some help.
    GT Level Member Spartanzz's Avatar
    Dec 2010
    Lawrenceville, GA
    so i am gunna try and get an intercooler from ZZP when i get my tax return my main question is i was cosidering getting a pully as well how small of a pully can i put on with just an intercooler on my car. other than a cold air intake i havent done anything to my 98 grand prix GTP. i have herd mixed things on this such as i can go as small as 3.0 with just the intercooler installed.
  2. #2 Re: looking at getting the ZZp intercooler need some help.
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    With just a intake? You need ATLEAST a down pipe 3.3 IMO. With headers- 3.0/2.9
    This is assuming its a s2 IC
    Other things you really should do other then The intercooler is ported LIM and blower, 104 autolite spark plugs,and headers.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: looking at getting the ZZp intercooler need some help.
    if you do go down a size, only go to a 3.4... The intercooler is a great investment, I have the S2 from zzp and love it (dont get the short stack its a waste of money). But with just an IC, its really not gonna do a whole lot for your car until you get some flow mods (exhaust, cam, rockers, etc...) so I wouldn go that small in pulley size...
    and another thing you should get is a scan gauge now in case your IC pump fails so you can see the KR....
  4. #4 Re: looking at getting the ZZp intercooler need some help.
    Dec 2010
    Lawrenceville, GA
    so would you all recomend getting the flow mods or basicly what i can with the money instead of getting the IC right now? this is all assuming i do get enouigh money from my return lol
  5. #5 Re: looking at getting the ZZp intercooler need some help.
    As long as it is tuned right...who the hell needz flow mods.
    Buddy of mine is running a 3.2" knock free on his '97 with just a short stack...and all he has for supporting mods is a open cone and a catless 3" DP...everything else on that car is BONE STOCK. Just keep in mind GM had a intercooler on the concept GPX back in '96 and it ran down the F-Body with ease at the time...factory pulley was a 3.0" or 3.1"... http://image.motortrend.com/f/161598...GPX+engine.jpg
    Note the braided lines above the belt for the IC lines...
    If I were you...I'd get the stage 2 intercooler and headers...you'd be set. Also...is it a 97-03 or '04+? Because that'll make a huge difference on the pulley you'll be running. Anything lower than a 3.2" on a 97-03 car you're going to be needing injectors...intercooler and headers on a '04+ car is a 3.4"...done.
  6. #6 Re: looking at getting the ZZp intercooler need some help.
    Hagerstown,Md
    KR just tells half the story. Whats his afr whats his timing. Just saying no Kr is very misleading. If you have zero KR and a afr of 10.2 and 13 degrees WOT timing...Then running that pulley size isnt what you want. You want to run the pulley that you can run 11.6-11.8 afr with Atleast 17 degrees timing with little to no KR. Intercooled. Non intercooled id shoot for 11.3-11.5
    But Each car is different. And your gonna have to scan and see where your at
  7. #7 Re: looking at getting the ZZp intercooler need some help.
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Why didnt GM go ahead with the stock intercooled l67 idea? That probably would have solved the whole knock issue.
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  8. #8 Re: looking at getting the ZZp intercooler need some help.
    I was refering to just having the IC with the stock tune... of course with a tune you can get a little more out of it...
    oh and stock injectors are good till a 3.1
  9. #9 Re: looking at getting the ZZp intercooler need some help.
    Tofu Delivery Boy Lsick7's Avatar
    MO
    I hope you're not talking about Christian....
    Gold Digger - still broke, lawn ornament
    05 M6 PBM GTO - Corsa exhaust, aem intake, bmr drag bags. More whenever I haz monies
  10. #10 Re: looking at getting the ZZp intercooler need some help.
    Quote Originally Posted by gtpsleeper View Post
    Hope your jokin...furealz
    Quote Originally Posted by Lsick7 View Post
    I am...only because I've seen the scans...not saying the car is fast by any means...trust me.
  11. #11 Re: looking at getting the ZZp intercooler need some help.
    MO
    I don't doubt he is knock free, but I gotta say for an ic'd car I stuck it to him hard with my old 3.4.
  12. #12 Re: looking at getting the ZZp intercooler need some help.
    I've theorized that a Gen V is as good or better (temp wise) than an SS IC. Costwise, it's something to mention if money is an issue.
  13. #13 Re: looking at getting the ZZp intercooler need some help.
    mines doin just fine...
  14. #14 Re: looking at getting the ZZp intercooler need some help.
    GTX Level Member Juanmiguel's Avatar
    Mexico
    Dude, on our write up it says this:
    "Also keep in mind that if you do happen to get away with dropping lower than a 3.1”/3.0” pulley, your stock fuel injectors will probably run static (out of fuel) and you’ll need bigger injectors."
    By that I also understand that the stock injectors are good enough until a 3.1 pulley.
  15. #15 Re: looking at getting the ZZp intercooler need some help.
    Charles City, IA
    Money.
    SMGPFC Two Nipple General
  16. #16 Re: looking at getting the ZZp intercooler need some help.
    Hagerstown,Md
    I was hitting 105 percent injector duty cycle on a 3.4 pully with high compression lol. Id imagine a 3.1 on a gtp would be well into the 100's as well
  17. #17 Re: looking at getting the ZZp intercooler need some help.
    Depends on your IDC.
    It should be 80% or lower.
  18. #18 Re: looking at getting the ZZp intercooler need some help.
    Right Juan...lower than a 3.2" you will start to run static...then again, every car is different. That thread is just a basic guideline...and it needs to be re-done...but it still gives the simple way to mod these cars effectively with the knowledge you need.
  19. #19 Re: looking at getting the ZZp intercooler need some help.
    Jan 1970
    Maquoketa, Iowa
    When every car usually has 100k+ miles on a stock fuel pump and the setups are different, it depends on the tune and your particular car. Injectors can only do so much to keep up. Pulley size is most of the time irrelevant.
  1. zzp intercooler vs wbody store intercooler ?
    By boostedgtp13 in forum Off Topic Discussion
    Last Post: 05-04-2010, 02:40 AM
  2. zzp intercooler
    Last Post: 08-31-2008, 06:14 PM
  3. intercooler?
    Last Post: 08-04-2008, 12:53 AM
  4. SS intercooler ?'s
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2008, 12:11 AM
  5. which intercooler ???
    By DunriteDiesel in forum Off Topic Discussion
    Last Post: 06-15-2008, 10:40 PM
