Hope your jokin...furealz
I am...only because I've seen the scans...not saying the car is fast by any means...trust me.
Dude, on our write up it says this:
"Also keep in mind that if you do happen to get away with dropping lower than a 3.1”/3.0” pulley, your stock fuel injectors will probably run static (out of fuel) and you’ll need bigger injectors."
By that I also understand that the stock injectors are good enough until a 3.1 pulley.
