Thread: AjL227's XP, S2 IC, 2.8" CompG build
Results 1 to 20 of 113
Threaded View
  1. #27 Re: AjL227's XP, S2 IC, 2.8" CompG build
    GTP Level Member AjL227's Avatar
    IL
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    Maybe Im not following this right but if that IC core was leaking bad like you said get ready for another bottom end. Any Idea how much got into the engine? And hope you've changed and kept an eye on the oil. GL hope it runs great now that the cores fixed.
    My I/C system has had 2 kinked hose locations and all three FMHE thread fittings leaking since it was first installed back in 2010, a while before the motor tear down. It had always been topped off daily with water, ZZP jew'd me with black rubber hoses in the S2 kit, so it most likely never got all the air bled out either. Pump connection got enough salt water exposure to corrode away the connector pins, come winter 2010.
    I installed a new I/C pump a few days before I did my injectors back in June 2011, I only filled it once, barely bled it initially. Next time I checked, the level had dropped more than the usual bleed cycle, so I checked for leaks. There were no external leaks anywhere; besides the seeping thread fittings, so I drained the whole system and condemned the core.
    End of August, replaced the I/C core, modified FelPro S/C gaskets to match the I/C core and ported LIM, replacing the POS garlocs once and for all, ran all new silicone hoses, resealed the horribly sealed plates, and applied paste to the threaded FMHE fittings. As you can see, it is all 50/50 green now and ready for winter.
    I'm thinking and starting to agree that the I/C core tube probably got damaged moving it sometime during the cam tear down, in January..
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  1. Are the compg gtp's faster than the non compg gtp's?
    By GMCARS4LIFE in forum Off Topic Discussion
    Last Post: 03-07-2011, 09:19 PM
  2. Turbo Build "UPDATED 12/22/2010"
    By bbptech in forum Turbo
    Last Post: 12-22-2010, 12:06 PM
  3. 04 CompG from MN here, Hello!
    By chili in forum Introductions/Noob Questions
    Last Post: 06-06-2009, 05:15 AM
  4. My CompG
    By RKELC in forum Visual/Body Modifications
    Last Post: 04-29-2008, 06:57 PM
