I like.
And jesus small pulley. Would tuning a bigger pulley better make any difference, or are you just trying to get it faster quicker with pulley drops?
I like.
You may not be. Copper spray is a must if I recall correctly.
When the car trapped 12.9 @ 110MPH, I was running a 3.0" with 27* of timing and 11.4 AFR on E85, with room for more timing.
Seeing as I'm not gaining much more power anywhere over 23* of timing, more boost is a must.
here is a direct quote from Cometic.
i hope this is right. because this is what i went off when i torqued down my heads
"Cometic Multi-Layer Steel (MLS) head gaskets go on dry because they are coated with a sealant. Each MLS head gasket is coated with a .001" thick viton rubber that is bonded to the outer stainless steel layers. Adding an additional sealer can hinder the performance of an MLS head gasket.
