Thread: gtp s/c rotor swap HELP
Results 1 to 20 of 38
  1. #1 Re: gtp s/c rotor swap HELP
    TDCRacing
    Guest
    Quote Originally Posted by Cyko View Post
    130kish... see, you know how you get the normal chatter/rattle from the s/c assembly at idle? That sound seems to go away whenever this other noise starts... how would I check for timing belt damper?
    just take the timing chain cover off...more complicated than that...maybe someone else can fill u in since i have never done one...milage sonds about right for the dAmpner though
  2. #2 Re: gtp s/c rotor swap HELP
    May 2008
    Portsmouth, NH
    That would be great... any takers? Also, how would one go about REPLACING the Dampener, and do we have a price range?
  3. #3 Re: gtp s/c rotor swap HELP
    TDCRacing
    Guest
    hmmm...couldnt find the dampner...figured it would come with anew chain...but it didnt look like it...i would change the chain and sprockets too if that the problem...the chain set is 120.00
  4. #4 Re: gtp s/c rotor swap HELP
    Barksdale AFB, LA
    Timing chain (if needed):
    ZZ Performance
    Damper:
    ZZ Performance
    I don't see any reason to change the sprockets. You have to remove the front cover of the engine to do this stuff. Not too hard, but somewhat involved.
    2009 Subaru Impreza WRX STI
  5. #5 Re: gtp s/c rotor swap HELP
    May 2008
    Portsmouth, NH
    I was looking at a writeup on a random webpage, and this looks like it's gonna suck... What're the chances that it's NOT the timing dampener, as the front of the motor's on the OPPOSITE side of the throttle body (which seems to be the source...
    I'm wondering if it's something as simple as I torqued it too hard and ovalled out one of the holes that the s/c impeller pegs sit in, and that's moving?
  6. #6 Re: gtp s/c rotor swap HELP
    Barksdale AFB, LA
    Oh, I thought it was from the passenger side of the engine. Just tossing ideas out there.
  7. #7 Re: gtp s/c rotor swap HELP
    May 2008
    Portsmouth, NH
    at this point man, I'll listen to any ideas... I appreciate you guys even posting up some ridiculous ones LoL.... I just don't really feel like pulling apart the front of the engine (when I work full time, the wife works full-time and leaves the second I get home, and have a toddler and identical twin infants) when time is tight and I can't really dedicate even a solid day, let alone the two I was recommended, yanno?
    At any rate, I really REALLY appreciate all the input and suggestions from you guys on the forums and I'm sure whenever this problem gets fixed, it'll be a solution from here.
  8. #8 Re: gtp s/c rotor swap HELP
    Wichita, KS
    Narrow it down.
    Remove your supercharger belt and start the car and see if the sound is still there.
    Yes, then its something else motor wise.
    NO, and then you have it narrowed down to the supercharger, or its pulleys for the belt.
    The clunking could also be a worn out balancer on your crank as well to even a bad idler or tensioner pulley on the accessory belt or even on the supercharger belt.
    Your rotors you removed, how they have the shinny spots on the blades, thats the rotors making contact with each other. I have seen them worn down to the metal below before from them knocking around in there. Your case needle bearings, deep inside the case could be worn out, or you switched your bad set of rotors with another bad set. Happens.
    But before we start jumping further to replacing expensive parts, check the above carefully, and go from there. Its not hard to pinpoint the sound. Better than finding a small fluid leak, or tracking down an electrical short. Trust me.
    ~F~
  1. R1 Concepts Brake Rotor Install
    By GeddyLee in forum Brakes/Suspension/Chassis
    Last Post: 07-01-2008, 08:47 PM
  2. top swap 05 gp
    By duane9586 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-05-2008, 06:28 PM
  3. M90 Rotor Bearings
    By Cyko in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-23-2008, 02:17 PM
  4. Rotor pack bearings
    By marchi1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2008, 05:36 PM
  5. top swap
    By Grandprixboy1224 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2008, 04:23 PM
