Thread: gtp s/c rotor swap HELP
Results 1 to 20 of 38
  1. #1 Re: gtp s/c rotor swap HELP
    See if you can't pop the coupler off of the drive. If you can, then you should be able to pull the snout straight up, and slide the rotors out. Otherwise you will surely not be able to slide the rotors / snout off together without hitting anything. I have never swapped rotors with the s/c on the car, but I would think this would work.
    Otherwise, you could have removed the alt. bracket in the time it took to make this post. Good luck.
  2. #2 Re: gtp s/c rotor swap HELP
    Wichita, KS
    There is no way to remove the rotors safely from the housing with out either:
    1. removing the supercharger from the motor
    2. removing the alternator and the alternator bracket
    The only service you can really do to these with out removing other parts that are in the way is changing the supercharger oil, and the coupler (removing the snout)
    In your case, the alternator and the bracket do have to be removed before you can move on.
    ~F~
  3. #3 Re: gtp s/c rotor swap HELP
    May 2008
    Portsmouth, NH
    I got the new rotors in, after much frustration and a lotta cleaning up coolant, but the car still makes the rattling/hitting sound when I hit high RPM or when I'm pushing too much at a shift point... is there something I'm overlooking? It's got fresh oil, and two full bottles of it, all the seals seem to be holding just fine (red RTV) and the new rotors looked/felt alright going in... what could my problem be? Could I have flat out spun a bearing in the block or something? The sound is almost definitely coming from the driver's side of the motor, and the s/c housing looked alright, the brief moments I took to look into it while I had the rotors out. Are there supposed to be bearings on the pegs at the backside of the impellers or something? The old set came out looking EXACTLY like the new set before I put it in... Here's what the old ones look like... maybe that'll give some insight?
    gtp s/c rotor swap HELP Attached Images
  4. #4 Re: gtp s/c rotor swap HELP
    Barksdale AFB, LA
    You sure it's coming from the SC and not the front of the engine itself (I'm thinking timing chain damper)?
    2009 Subaru Impreza WRX STI
  5. #5 Re: gtp s/c rotor swap HELP
    TDCRacing
    Guest
    Quote Originally Posted by Sabrewings View Post
    good point...how many miles on the car???
  1. R1 Concepts Brake Rotor Install
    By GeddyLee in forum Brakes/Suspension/Chassis
    Last Post: 07-01-2008, 08:47 PM
  2. top swap 05 gp
    By duane9586 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-05-2008, 06:28 PM
  3. M90 Rotor Bearings
    By Cyko in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-23-2008, 02:17 PM
  4. Rotor pack bearings
    By marchi1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2008, 05:36 PM
  5. top swap
    By Grandprixboy1224 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2008, 04:23 PM
