Thread: Trouble Code Help
Results 1 to 13 of 13
Threaded View
  1. #10 Re: Trouble Code Help
    SE Level Member Justin48's Avatar
    Groton, CT
    sounds like the boost bypass valve... open the hood with it running take off the cover if you have it on look at the soloide on the front drivers side of the supercharger with the lever coming out of it going in the side of the supercharger and snap the throttle and see if it moves... make sure the electrical connections look good and tight and check the vaccume line to make sure its connected and in good shape thats my best guess...
    Last edited by Justin48; 11-14-2010 at 02:45 AM. Reason: didn't specify location of solonide
    zzp mps 3.2-3.4", prj intercooler core, bosh pump, zzp stage 3 front mount, xp cam, 130# springs,double roller chain, 42.5# injectors, sd headers, 4" fwi, modified prj tune(inprogress) performance shift add, aem wide band, aeroforce.
  1. Trouble code P0455
    By powerranger262 in forum General Tech Discussion
    Last Post: 09-23-2014, 03:09 PM
  2. Cylinder 5 misfire trouble code P0305
    By michellebuck76 in forum General Tech Discussion
    Last Post: 04-11-2013, 06:02 PM
  3. P0442 trouble code?
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2008, 10:33 AM
  4. General OBD-1 Trouble Code List
    By Sinister Performance in forum PCM Tuning
    Last Post: 02-22-2008, 06:09 AM
  5. General OBD-2 Trouble Code (DTC) list
    Last Post: 02-22-2008, 02:15 AM
