Thread: Cylinder 5 misfire trouble code P0305
Results 1 to 9 of 9
  1. #1 Cylinder 5 misfire trouble code P0305
    Apr 2009
    ventura county
    My 1999 Grand Prix (Supercharged 3800) has a little hitch in her gitty up. Ran a diagnostic and the trouble code came up P0305, cylinder 5 misfire. Makes sense right!? I have changed out the plug, wire, and the coil and she is still misfiring. Any suggestions as to a solution would be greatly appreciated. Thanks in advance, Michelle
  2. #2 Re: Cylinder 5 misfire trouble code P0305
    Apr 2009
    Maine
    Could be a cracked head gasket. Start it up and check for a hissing noise by cylinder 5. It could also be a plugged injector so you could try replacing that. It MIGHT help to run some of that bottled injector cleaner crap through a tank of gas. I've never used the stuff, I always figured it was a gimmick. It could potentially be a cheap fix, but I'd wait and see what others think.
  3. #3 Re: Cylinder 5 misfire trouble code P0305
    Apr 2009
    ventura county
    Thanks for your feedback J. I tried that fuel injector stuff already and I as well believe that is a gimic or just a bandaid solution to a bigger problem to come. No hissing noise but i am going to try replacing the injectors is the cost is not too high. Thanks again for your help. Michelle
  4. #4 Re: Cylinder 5 misfire trouble code P0305
    Mar 2012
    Southeast Indiana
    Purchase the set of 6 from ZZPerformance, heres's a link GM ACDelco - 33# GM EV1 Injectors #GM-0280155737-6 if you want to save the money, they are remaned/rebuilt and tested. If you want to just get 1 new injector they can run between $80-$100 to purchase.
  5. #5 Re: Cylinder 5 misfire trouble code P0305
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    Quote Originally Posted by michellebuck76 View Post
    Before you buy new injectors, switch the one off of cylinder 5 with cylinder 3. If the misfire changes to cylinder 3, you know it's the injector. If not, move on to the next possibility. From personal experience, I know it can get real expensive chasing down a misfire.
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  6. #6 Re: Cylinder 5 misfire trouble code P0305
    St. Louis
    Um, guys, this thread is 3 years old and the OP hasn't been on since 04-26-09. I would think she figured it out by now
  7. #7 Re: Cylinder 5 misfire trouble code P0305
    Jul 2012
    Could always help the next person who looks it up
  8. #8 Re: Cylinder 5 misfire trouble code P0305
    Jan 2013
    Ohio
    It helps people like me who currently has the exact same problem and i am currently going through the steps suggested here to try and resolve the problem. Currently i have replaced the plugs and wires but no fix yet. I will try to update what the final solution turns out to be.
  9. #9 Re: Cylinder 5 misfire trouble code P0305
    Dec 2008
    Essex, UK
    I've just had this happen to me yesterday, my car was fine in the morning but running sick as a dog in the afternoon. Flipped the hood and there is oil all over the front of the engine; looks like the valve cover gasket has gone again! Threw the P0305 code cylinder 5 misfire. Have ordered plugs and leads and a replacement coil,( just in case), and I've already got a spare gasket. Is there anything else I should look for, only being in the UK parts take forever to arrive here?
    Plugs and leads already on the car look original, so I'm changing those anyway. The car is a 1998 Grand Prix GT. Also threw a code for the Crank Pos Sensor, as the tacho stopped working and the Traction Off light came on.
  1. Cylinder 6 misfire with a p0102
    By icolex1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-29-2009, 05:16 PM
  2. All Cylinder Misfire after LIM Change and Vac Leak?
    By Lawngoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-12-2009, 06:32 PM
  3. Cylinder #4 misfire
    By Kompton in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2009, 08:41 AM
  4. P0300 multiple cylinder misfire code
    By Reeddawgy in forum PCM Tuning
    Last Post: 07-15-2008, 07:42 PM
  5. #4 cylinder misfire
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 06:16 PM
