It's tough to sneak the flywheel out w/o unbolting the trans from engine. If you want to fix any part of the rotating assembly and don't take it to a machine shop (in which case a used motor is usually cheaper) then you will have the 200 mile motor. In about 200 miles it'll likely fail again.
werd.
