Thread: Removing Engine and Transmission together
Results 1 to 10 of 10
  1. #1 Removing Engine and Transmission together
    Niagara
    Has anyone lifted the engine and trans out while they are still bolted together? Are there any clearance issues? Any help would be appreciated.
  2. #2 Re: Removing Engine and Transmission together
    May 2008
    staten island,NY
    i would drop the subframe, makes more sense
  3. #3 Re: Removing Engine and Transmission together
    Charles City, IA
    I would drop the subframe if you are taking both out.
    SMGPFC Two Nipple General
  4. #4 Re: Removing Engine and Transmission together
    Apr 2009
    stockton ca
    drop subframe if you have a lift in a driveway or with out a lift the top may be an easier option just would ad a couple hours to things i would think
  5. #5 Re: Removing Engine and Transmission together
    Niagara
    I dont have access to a hoist since the local DIY shop closed, and I cant jack it up high enough to drop the subframe, and get the motor out, so i guess ill try to pull it through the top. Thanks for the info.
  6. #6 Re: Removing Engine and Transmission together
    Banned - Busted For Scamming
    Feb 2009
    You can pull it out top no problems.
  7. #7 Re: Removing Engine and Transmission together
    May 2008
    McHenry IL
    yupp
  8. #8 Re: Removing Engine and Transmission together
    Apr 2016
    Seattle
    Reviving this thread....
    I have a 98 and 99 Grand Prix GT and want to hoist the engine and transmission bolted together from the top and drop in the other car without dropping sub frame. This seems like a simpler approach to swapping both engine and transmission together. Anyone with knowledge or experience on this?
  9. #9 Re: Removing Engine and Transmission together
    Search on my user name and what you are trying to do. It's in the How to section.
  10. #10 Re: Removing Engine and Transmission together
    Apr 2016
    Seattle
    Found it Bill,
    Thank you.
    I knew this could not be that complicated.
  1. Removing spoiler?
    By rocafella2032 in forum General Tech Discussion
    Last Post: 01-24-2010, 12:31 AM
  2. Removing Engine and Tranny Together for Dummies Like Me (Write Up)
    By JoeMama in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-03-2009, 06:24 AM
  3. Removing Oil Pan
    By dhoeschen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-06-2009, 04:27 PM
  4. Engine and Transmission Compatability
    By slednut in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2009, 10:20 PM
  5. how many bolts are there from the transmission to the engine???
    By 98bdgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2009, 08:16 PM
