Thread: Rotating assembly repair without removing engine?
Results 1 to 18 of 18
  1. #1 Re: Rotating assembly repair without removing engine?
    Apr 2009
    Fort Worth TX
    Sorry for replying to an old post but I just wanted to give an update and ask a couple questions.
    I unbolted the down-pipe, removed the upper mounts, jacked the engine up, removed the lower mount bracket and dropped the oil pan. The mount bolts are hellacious and it was hell getting the oil pan off this car due to the interfering pickup tube. I used a 15mm pivoting ratchet wrench to remove the mount bolts.
    Anyway, I removed the rod caps and someone has been in this engine - big time. Three rod journals are trashed and it has mixed bearings; std, 0.010 etc. I made the decision to rebuild the short block.
    Question: What should I replace on the transmission while I have this thing apart?
    Question: I would like to eliminate the balance shaft. Should I just mig weld the rear oil galley closed or is there a better/safer way? I was thinking milling a rod down to fit the hole and just spot welding it in.
    Thanks in advance for any replies.
  2. #2 Re: Rotating assembly repair without removing engine?
    To keep the pickup tube from interfering, simply remove the oil level sensor before pulling the pan.
    On the trans. Pick up a set of channel plate gaskets. Then go in and replace the 4th hub clutch shaft. Frequently you can pick them up off Ebay for $45ish. Pull the side pan, oil pump, then take the valve body and channel plate together. That way you don't deal with the checkballs or two more gaskets. Zip up the 4th clutches and slide in the new shaft. Reassemble and enjoy knowing you won't lose 4th due to sheared splines.
  1. Removing Engine and Transmission together
    By topswap in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-03-2016, 09:32 AM
  2. 04+ removing headlight lens from assembly
    By Piggy in forum Visual/Body Modifications
    Last Post: 07-27-2010, 04:10 AM
  3. Removing Engine and Tranny Together for Dummies Like Me (Write Up)
    By JoeMama in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-03-2009, 06:24 AM
