Thread: Rotating assembly repair without removing engine?
Results 1 to 18 of 18
  1. #1 Re: Rotating assembly repair without removing engine?
    It's tough to sneak the flywheel out w/o unbolting the trans from engine. If you want to fix any part of the rotating assembly and don't take it to a machine shop (in which case a used motor is usually cheaper) then you will have the 200 mile motor. In about 200 miles it'll likely fail again.
  2. #2 Re: Rotating assembly repair without removing engine?
    Donating Users kfish's Avatar
    Ohio
    werd.
  3. #3 Re: Rotating assembly repair without removing engine?
    Quote Originally Posted by kfish View Post
    werd.
    werd werd
    or werdx2
    or werd^2...well...
    that's be like werd werd...
    ya.
  1. Removing Engine and Transmission together
    By topswap in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-03-2016, 09:32 AM
  2. 04+ removing headlight lens from assembly
    By Piggy in forum Visual/Body Modifications
    Last Post: 07-27-2010, 04:10 AM
  3. Removing Engine and Tranny Together for Dummies Like Me (Write Up)
    By JoeMama in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-03-2009, 06:24 AM
