so i had a friend who works at a tech school take a spin at installing my headers, he did it for free and i didnt think there was much he could mess up.
WRONG! After i get the car back i start it and it starts up rough, i was like ****, then i get a ses light saying tps sensor and i pop the hood and find a vacuum leak, fixed so now im thinking okay everythings okay, so i run it down to the local exhaust shop about 4-5 miles away on open headers because he doesnt have access to a welder and when the owner puts it on the lift and goes wtf! you have gasoline on the down pipe and your mid pipe, so im like **** okay, weld them together and see if anything gets better. no. So im thinking okay ill drive it for a mile or two and see if it gets better or worse, gets worse, i bring it home and pull it into the garage and pop the hood. All i can smell is raw gas and my cross over pipe has an exhaust leak and is literally shooting gas out of it. the raw fuel is coming out of my tail pipe as well, its as if my injectors arent pulsating but just continusly running. I decided to drive it over to the shop and park it for the time being, my mechanic was there took a look said maybe maf but cant tell at the moment, but on the way over there my car completely bogged down and shut down and started back up roughly.
Mods: SD headers, 3.5 pulley, 3800 performance pcm, poly mount dog bone bushings, cai, no cat, and i think thats it.
Also, i have new plugs new wires and new coil packs not even put in a month ago and its been fine up until now.
Any advice would be great, i may be done with the 3800 world if its to expensive of a fix.
