Thread: help. bogging, raw fuel, headers...
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 94
  1. #1 help. bogging, raw fuel, headers...
    GT Level Member Mitchstrp's Avatar
    Missouri
    so i had a friend who works at a tech school take a spin at installing my headers, he did it for free and i didnt think there was much he could mess up.
    WRONG! After i get the car back i start it and it starts up rough, i was like ****, then i get a ses light saying tps sensor and i pop the hood and find a vacuum leak, fixed so now im thinking okay everythings okay, so i run it down to the local exhaust shop about 4-5 miles away on open headers because he doesnt have access to a welder and when the owner puts it on the lift and goes wtf! you have gasoline on the down pipe and your mid pipe, so im like **** okay, weld them together and see if anything gets better. no. So im thinking okay ill drive it for a mile or two and see if it gets better or worse, gets worse, i bring it home and pull it into the garage and pop the hood. All i can smell is raw gas and my cross over pipe has an exhaust leak and is literally shooting gas out of it. the raw fuel is coming out of my tail pipe as well, its as if my injectors arent pulsating but just continusly running. I decided to drive it over to the shop and park it for the time being, my mechanic was there took a look said maybe maf but cant tell at the moment, but on the way over there my car completely bogged down and shut down and started back up roughly.
    Mods: SD headers, 3.5 pulley, 3800 performance pcm, poly mount dog bone bushings, cai, no cat, and i think thats it.
    Also, i have new plugs new wires and new coil packs not even put in a month ago and its been fine up until now.
    Any advice would be great, i may be done with the 3800 world if its to expensive of a fix.
    1.8 RR's, Speed daddy headers, 180 stat, Open Cone, GBP tune, 3.5 pulley, and ported blower.
  2. #2 Re: help. bogging, raw fuel, headers...
    Jul 2008
    sumter,south carolina
    did he put o2 sensors in?
    02 GTP with mods 05 GP for DD
  3. #3 Re: help. bogging, raw fuel, headers...
    Missouri
    upstream and downstream
  4. #4 Re: help. bogging, raw fuel, headers...
    Jul 2008
    harnesses plugged in?
  5. #5 Re: help. bogging, raw fuel, headers...
    Missouri
    yeah, had to use the extension for the upper one
  6. #6 Re: help. bogging, raw fuel, headers...
    Jul 2008
    i still consider myself a noob.. but seems like it would be o2 related. specifically the front sensor.
  7. #7 Re: help. bogging, raw fuel, headers...
    Missouri
    yeah, me too. i was think like MAF sensor
  8. #8 Re: help. bogging, raw fuel, headers...
    Jul 2008
    if maf was good before.. i dont see why it would go bad after header install... positive he wired teh extension correctly?
  9. #9 Re: help. bogging, raw fuel, headers...
    Missouri
    he didnt wire, he just plugged it in. its a zzp extension, you would think that if it wasnt working it would send an o2 sensor code
  10. #10 Re: help. bogging, raw fuel, headers...
    Jul 2008
    no codes at all?
    edit.. also it takes time for codes to pop up.
  11. #11 Re: help. bogging, raw fuel, headers...
    Missouri
    i think it may be the extension, its for an 04+ could that be it?
  12. #12 Re: help. bogging, raw fuel, headers...
    Jul 2008
    not sure on that man... seems like it would be the same. maybe a faulty extension?
  13. #13 Re: help. bogging, raw fuel, headers...
    Missouri
    yeah actually the extension is for my car, and maybe thats it hopefully
  14. #14 Re: help. bogging, raw fuel, headers...
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    I think u may wanna see if he got the o2 sensors backwards not sure if it would do much but seems like it's worth checking out
  15. #15 Re: help. bogging, raw fuel, headers...
    Jul 2008
    screw the zzp extension... get some wire the same gauge as o2 wire harness.. splice it into the o2 harness wire.. not the actual o2 wire and see how that works.. thats what i did on mine.
  16. #16 Re: help. bogging, raw fuel, headers...
    Missouri
    pics? i dont get what your saying.
    thanks
  17. #17 Re: help. bogging, raw fuel, headers...
    Jul 2008
    basically just extend the the o2 plug. cut the plug off that plugs into the o2... and extend it with a wire thats the same gauge. feel me?
  18. #18 Re: help. bogging, raw fuel, headers...
    Missouri
    okay i understand, my buddies gp did the same thing but his was a maf
  19. #19 Re: help. bogging, raw fuel, headers...
    Delaware, OH
    Even if it had no O2 sensors hooked up it should run in open loop just like when the car is started in the morning. Almost like he neglected to hook a plug wire or two back up so it's just spitting raw fuel threw it. I'd take the easy route and check to make sure the plug wires are hooked up correctly first.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  20. #20 Re: help. bogging, raw fuel, headers...
    Jul 2008
    ^ didnt even think of that. butttttt it would be misfiring like a sob.
  1. car bogging down :(
    By Ricky21 in forum General Tech Discussion
    Last Post: 08-19-2010, 12:55 AM
  2. bogging?
    By backinblackgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-28-2010, 05:03 PM
  3. 97 gtp sputtering and bogging?
    By ebejer13 in forum General Tech Discussion
    Last Post: 05-30-2010, 05:15 PM
  4. '02 GT bogging down-?
    By Wolf02GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-01-2009, 02:53 PM
