Thread: Getting knock w/ 3.4 pulley & All suported mods
Results 1 to 20 of 30
  1. #1 Getting knock w/ 3.4 pulley & All suported mods
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    I just installed my zzp mps yesterday and i am getting up to 3* of knock @ WOT and i have all the supported mods installed. Speed daddy headers, AL104'S, 180 tstat w/ pcm & fans tuned for it, custom cat back dual exhaust system, zzp wizaired cai. Any and all help would be greatly appreciated.
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #2 Re: Getting knock w/ 3.4 pulley & All suported mods
    its the tune. get a better one.
    also, 3* is not a lot, even on a 3.4 pulley.
  3. #3 Re: Getting knock w/ 3.4 pulley & All suported mods
    Nov 2009
    Grand haven
    torque managment is doin it. Listen to bio ^^
  4. #4 Re: Getting knock w/ 3.4 pulley & All suported mods
    Bowie, MD
    I have a DHP tuner. So i basically have to tune my torque management? Should i tune myself or get an intense tune and start from there and modify the bin as i add more mods?
  5. #5 Re: Getting knock w/ 3.4 pulley & All suported mods
    Should just get a damn DHP PCM like a told you to months ago.
  6. #6 Re: Getting knock w/ 3.4 pulley & All suported mods
    Buying a tune doesnt make any sense to me if you have a tuner find someone thats running a 3.4 setup and modify their bin file that shouldn't be to hard.
  7. #7 Re: Getting knock w/ 3.4 pulley & All suported mods
    you have a powertuner? hook that **** up and use it!
    torque management is pulling timing in the upper rpm to save your transmission. once you push the limits off all the torque measurements way out it goes away. then your transmission blows up, or at least mine did.
  8. #8 Re: Getting knock w/ 3.4 pulley & All suported mods
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by GOTIT4CHEAP16 View Post
    Post a scan on www.scandepot.net scan the following:
    Throttle position
    Boost PSI
    RPM
    Speed
    LFT's Long term
    O2 in MV
    Maf in HZ not Lb
    Timing
    Intake air temps
    Injector duty cycle
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  9. #9 Re: Getting knock w/ 3.4 pulley & All suported mods
    Bowie, MD
    Quote Originally Posted by 01gpgt01 View Post
    Throttle position
    Boost PSI
    RPM
    Speed
    LFT's Long term
    O2 in MV
    Maf in HZ not Lb
    Timing
    Intake air temps
    Injector duty cycle
    I couldnt even find some of those to scan but here is my scan though. I think im going to do what 02grandprixiraqvet said and find someone with a 3.4 tune and modify it for my car. Maybe someone on the powertuner site can give me one. Do any of you guys have one i could have? Id appreciate it.
    october scan from gotit4cheap16 -- Scan Depot dot net
  10. #10 Re: Getting knock w/ 3.4 pulley & All suported mods
    Jul 2008
    sumter,south carolina
    do u have a vibration in floorboard under heavy load?
    02 GTP with mods 05 GP for DD
  11. #11 Re: Getting knock w/ 3.4 pulley & All suported mods
    Hagerstown,Md
    That scan was pretty Useless with out knowing 02's,timing, And throttle position. But from what I see the pcms pulling fuel WOT and your trims are all over the place. Which isnt good. Your maf needs a good tune.. http://www.scandepot.net/viewscan.php?pk=5280 this is what you want your scan to look like. If I were you I would learn how to scan and tune. It will only help you in the long run. Load in the correct pids and post another scan For your reference http://wiki.opentuner3800.com/index....et_a_Good_Scan Ignore the VE tune all together its worthless
  12. #12 Re: Getting knock w/ 3.4 pulley & All suported mods
    Hagerstown,Md
    That knock isnt false. False knock is like 0,0,0,0,3.8,0,0,0,0, When knock builds stays consistent like in his scan its real
  13. #13 Re: Getting knock w/ 3.4 pulley & All suported mods
    Jan 1970
    Maquoketa, Iowa
    I wouldn't get another file off of a random car. If anything, use a dhp 1.0 you can get off the powrtuner website until you learn how to scan and tune properly yourself. Make your own tune so you know whats changing or has changed.
    I would download UvScan to scan. Then Eddies table modifier to do a bunch of maf tuning. Make small changes each time and flash it with powrtuner. Make sure to save the files in order so you can always go back to something if you don't like that change.
  14. #14 Re: Getting knock w/ 3.4 pulley & All suported mods
    Jul 2008
    my downpipe on sway bar held constant 5-6* with a matco scanner through top of each gear on stock pulley with intake and headers. just puttin it out there. and i have the same headers he has.
  15. #15 Re: Getting knock w/ 3.4 pulley & All suported mods
    Topeka, KS
    Is your sway bar flipped ? IF NOT... flip it so the triangle points down. Then it won't hit your downpipe of your header.
  16. #16 Re: Getting knock w/ 3.4 pulley & All suported mods
    Jul 2008
    i flipped mine and it still rubs when taking a hard curve or turn.
  17. #17 Re: Getting knock w/ 3.4 pulley & All suported mods
    Bowie, MD
    No my sway bar isn't flipped...at least im not sure it is. I didn't really pay attention when it was being installed by the shop. I will take it to them later and check when it stops raining.
    I have uvscan but whenever i click and open install.bat like the zip instructions stated to do before opening uvscan, i always get an error so im using the powrtuner program to scan.
    Here is the scan i did this morning on my way home from work. It was raining and 51 degrees outside. But i'm not sure why some sections have those lines on them and are blank. I was at lights so that's the scan is as long as it is and took me that long to go WOT. Only thing that does not show is vehicle speed even though i added that to scan.
    October Scan 2 from gotit4cheap16 -- Scan Depot dot net
  18. #18 Re: Getting knock w/ 3.4 pulley & All suported mods
    Hagerstown,Md
    I dont see 100 percent wot anywhere on that scan. I see 80 percent either Your TPS is reading wrong or you didnt go WOT. Replace the TPS and check to make sure the Throttle body cable is pulling the TB the whole way open. Also you are lean, Add 3 percent fueling to the 7,250 to 11,500 HZ Remember to add 2.5 to 7KhZ 2 percent to 6,750. 1.5 percent to 6,500 and so forth so it doesnt create a spike
  19. #19 Re: Getting knock w/ 3.4 pulley & All suported mods
    Bowie, MD
    Yea my foot wasnt all the way down on the peddle. I was afraid i would mess my engine up because of the knock. But here is a better scan.
    October Scan 3 from gotit4cheap16 -- Scan Depot dot net
  20. #20 Re: Getting knock w/ 3.4 pulley & All suported mods
    Hagerstown,Md
    You are way lean. Check rail pressure. You need to add alot of fuel if rail pressure is good. I suspect you have a fueling issue. Yeah dont go WOT lol. Your 02's are hitting in the 700's you want the in the 940 range Is this on a stock maf tune or something?
  1. Knock because of crank pulley or fuel pump
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-16-2009, 10:27 AM
  2. smallest S/C pulley with no other mods
    By millfire517 in forum General Tech Discussion
    Last Post: 02-20-2009, 03:04 PM
  3. new mods with knock or no?
    Last Post: 11-24-2008, 09:59 PM
  4. new mods with knock or no?
    Last Post: 11-23-2008, 07:13 PM
  5. could i run a 3.4 pulley with these mods?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2008, 03:17 PM
