Thread: SD Headers installed and A+++++
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 21 to 40 of 101
  1. #21 Re: SD Headers installed and A+++++
    they dont do tail pipe testing here. they hook it up to the OBDII port and run like a 3 min test and youre done. i had no EGR on my car and easily passed with the code set to no report.
  2. #22 Re: SD Headers installed and A+++++
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Quote Originally Posted by 01gpgt01 View Post
    Maryland just does the obd2 scan. I passed with no cat FWIW
    How the hell did you do that??
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  3. #23 Re: SD Headers installed and A+++++
    Bowie, MD
    Quote Originally Posted by DCVING View Post
    Thanks for all the compliments, I personally like the look with the engine cover on, the subframe was easy to lower in the back, took 5 seconds to do with air gun and I lowered it just enough to sneeek the rear header by. The clamps are from NAPA, my buddy got them too me for 9 each. I do not have a cat in there and have no plans of installing one either. The gains were noticable for sure, I also noticed a huge diffrence in the response and also how much faster it revs out. I couldnt be happier with them. Sounds so much better too. It actually reduced the exhaust drone I had quite a bit.
    How many clamps do you have to buy?? I plan on getting my speed daddy headers installed about next month so i wan t to be prepared.
  4. #24 Re: SD Headers installed and A+++++
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by GOTIT4CHEAP16 View Post
    Set my p0420 and po0421 codes to non report SES enabled
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  5. #25 Re: SD Headers installed and A+++++
    Windsor (ON) Canada
    You need 2, 3" Band Clamps.. and 2, 2.5"
  6. #26 Re: SD Headers installed and A+++++
    Bowie, MD
    Oh okay. So basically as long as i have my powrtuner, ill be good. lol.
    Quote Originally Posted by Colossus View Post
    Thanks colossus. And i just found out yesterday that there is a NAPA about 16 miles from me. Unfortunately i went there today and found out they close by 2 and are closed Sundays. Ill be purchasing the clamps Monday.
  7. #27 Re: SD Headers installed and A+++++
    sorry is it 2.5 or 2.25?
  8. #28 Re: SD Headers installed and A+++++
    Donating Users Vegas_Matt's Avatar
    Jul 2010
    Las Vegas, NV
    here's your sizes lol
    <MiZzBeCcA>its not rape if you yell suprise
  9. #29 Re: SD Headers installed and A+++++
    This is what i thought... thanks
  10. #30 Re: SD Headers installed and A+++++
    That Matt beat out the regular Matt lawlz
  11. #31 Re: SD Headers installed and A+++++
    I was basing my info off of the picture, and i've purchased clamps based on that picture.
    Just would like some confirmation of that.
    I know my pace****ters are 2.5 at the Y so 2.25 seems small to me.
  12. #32 Re: SD Headers installed and A+++++
    Clamps? What are clamps? Custom 2 piece Leak-Free Pacesh1tters FTMFW
  13. #33 Re: SD Headers installed and A+++++
    no they're not... You have to have the HOOD off to install them? I call that fail.
  14. #34 Re: SD Headers installed and A+++++
    Bowie, MD
    Are these the right clamps? Got them from NAPA.
  15. #35 Re: SD Headers installed and A+++++
    those be the ones.
  16. #36 Re: SD Headers installed and A+++++
    Bowie, MD
    Thank you kindly matt. Cant wait to install them.
  17. #37 Re: SD Headers installed and A+++++
    neither can i....
  18. #38 Re: SD Headers installed and A+++++
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    We sell those easy seals at O'Reillys for cheaper than 9 bucks each.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  19. #39 Re: SD Headers installed and A+++++
    stainless and the proper style? Not the cheapo ones?
  20. #40 Re: SD Headers installed and A+++++
    Bowie, MD
    I dont even know if the ones i have are stainless steel?? It doesnt say so on the plastic lol
  1. Headers installed and temps under hood
    By Silver GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-06-2010, 04:40 PM
  2. Speed daddy headers installed.
    By EricGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 03:45 PM
  3. headers installed
    By boostedcompg in forum General Tech Discussion
    Last Post: 12-19-2009, 03:24 AM
  4. ZZP Headers installed!
    By Reptile in forum General Tech Discussion
    Last Post: 03-10-2009, 11:11 AM
  5. Got my car back today had slp headers installed
    Last Post: 07-06-2008, 11:25 PM
