Thread: No spark HELP!!!
Results 1 to 7 of 7
  1. #1 No spark HELP!!!
    Tweed, ON
    Hi there.
    I just finished changing a engine over to one from the same year. I used all my electrical all I did was drop in a newer engine and hook up the fuel and all the wiring.
    The thing cranks over, I can hear the pump and smell the fuel, however im getting no spark.
    all the electrical plugs are plugged in, all the grounds seem good. I just dont get it.
    My scan tool showed me that its reading the crank rpm, so im assuming the crank sensor is working as it should.
    Im really lost here.
    Thanks.
    Martin.
  2. #2 Re: No spark HELP!!!
    What is missing, spark or fuel?
  3. #3 Re: No spark HELP!!!
    Donating Users Brooks's Avatar
    Nov 2009
    baltimore, md
    I had the same symptoms when I changed to the Gen V, check the ICM (ignition control module). Somehow during the swap I wrecked mine. Replaced and it started right up.
    Gen V 98 Regal GS
    Baltimore, MD
  4. #4 Re: No spark HELP!!!
    I'd bet 10 bucks its the Ignition module (ICM). They ain't cheap...but that's probably the issue.
  5. #5 Re: No spark HELP!!!
    Nov 2009
    baltimore, md
    I was in a rush and needed mine, it was 150$ from auto zone. I have seen people sell them on the boards here for 20$ though. If its not your DD your in luck.
    Gen V 98 Regal GS
    Baltimore, MD
  6. #6 Re: No spark HELP!!!
    Yup...I work at AZ at night...got mine for 120...still...expensive.
  7. #7 Re: No spark HELP!!!
    Charles City, IA
    Did you check the ground for the icm?
    SMGPFC Two Nipple General
  1. 3.1 and no spark
    By TAYLORPCC in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-25-2010, 01:45 AM
  2. 5.3L V8 Spark Plugs
    By 06usafgxp in forum General Tech Discussion
    Last Post: 01-29-2010, 09:23 PM
  3. 72 gp sj no spark
    By rayzo63 in forum General Tech Discussion
    Last Post: 02-16-2009, 10:40 PM
  4. Spark
    By 99prixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-14-2008, 04:06 PM
  5. no spark
    By faboskay57 in forum General Tech Discussion
    Last Post: 07-10-2008, 07:41 AM
