Thread: High rpm engine problem
Results 1 to 20 of 29
  1. #1 Re: High rpm engine problem
    Willoughby, Ohio
    if the MAF was bad the idle would be all over the place, maybe dirty tho?
  2. #2 Re: High rpm engine problem
    Escanaba,MI
    Just wondering if anyone found out what was wrong? My car seems to have some similar problems! Thanks guys
  3. #3 Re: High rpm engine problem
    seattle
    Still dealing with this problem thought i would throw it back and see if anyone has any new ideas. Replaced the pre cat O2 sensor but that didn't help. Seems like some others are dealing with the same problem and i was hoping they found a fix and can give some advice. Also, could any of you guys in the know, tell me if a slipping s/c belt might be the culprit. Would this cause the problems i am having? Thanks.
  1. Engine problem 3.4L dohc
    By sheepeater in forum 3.4L V6 (LQ1) DOHC
    Last Post: 09-08-2010, 11:49 PM
  2. Engine Misfiring @ High RPMs
    By skiderek in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-08-2010, 05:57 PM
  3. 98 GTP high idle problem
    By mikegtp in forum General Tech Discussion
    Last Post: 10-09-2009, 02:05 PM
  4. engine idling high
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2009, 11:49 PM
  5. Engine problem???
    By WHITEHORSE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-07-2009, 11:11 PM
