Thread: High rpm engine problem
Results 1 to 20 of 29
  1. #1 Re: High rpm engine problem
    apply vacuum to the FPR.
    if fuel comes out then the FPR needs replacing.
    is the O2 wire touching any of your spark plugs?
  2. #2 Re: High rpm engine problem
    seattle
    will check the fpr after work tomorrow. thanks for the help. at this point i will try anything.
  1. Engine problem 3.4L dohc
    By sheepeater in forum 3.4L V6 (LQ1) DOHC
    Last Post: 09-08-2010, 11:49 PM
  2. Engine Misfiring @ High RPMs
    By skiderek in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-08-2010, 05:57 PM
  3. 98 GTP high idle problem
    By mikegtp in forum General Tech Discussion
    Last Post: 10-09-2009, 02:05 PM
  4. engine idling high
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2009, 11:49 PM
  5. Engine problem???
    By WHITEHORSE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-07-2009, 11:11 PM
