Thread: Series II vs Series III questions....
Results 1 to 4 of 4
  1. #1 Series II vs Series III questions....
    Iowa
    I am a little confused. I have a 2004 GTP that is making lots of rod noise. I have tracked down a motor that came out of the same year GTP. My top cover says that it is a series III and this engine block has a marking on it that says series II. There is a printed date on the valve cover that says 2004. Is it true that 2004 was a switchover year and they used up the series II blocks from years past? I am thinking that the series III is mostly if not completely a top end change and the blocks are identical. Any information would be appreciated. Thanks!
  2. #2 Re: Series II vs Series III questions....
    So far all the S3 motors I have seen have "Series II" on the block. Seems to be that GM never changed the mold for the block.
  3. #3 Re: Series II vs Series III questions....
    03-04 cars were hybrids of themselves...the 03's used the SeriesII engine and new '04+ transmission and the '04's used the leftover series II block and new trans...
  4. #4 Re: Series II vs Series III questions....
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    My 06 motor has 3800 stamped on the block.. No series number. That being said. 04-05 l67's recieved (aside from the blower) all upgraded internals found on the L32 motor. So if you found an 04 motor, it doesn't have to be an L32 if you're trying to save a few bucks. Just simply swap the LIM and GenV over to the new motor.
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  1. 2004 series 3 3800 swap to 1998 series 2 car?
    By carpenterbronco in forum General Tech Discussion
    Last Post: 04-13-2010, 11:12 PM
  2. Series II vs. Series III
    By butt86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2009, 11:31 AM
  3. Difference between series 1 and series 2
    By Superchargedbuick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2009, 01:50 PM
  4. Series III downgrade to Series II
    By Rolling Thunder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2009, 02:12 PM
  5. Using Series III A/C Compressor on a Series II
    By Rolling Thunder in forum General Tech Discussion
    Last Post: 05-21-2009, 01:14 AM
