Thread: Difference between series 1 and series 2
Results 1 to 8 of 8
  1. #1 Difference between series 1 and series 2
    connersville indiana
    I may be getting a mint buick riviera with a blown up series 1 and i can get a good running series 2 for 150 so I was wanting to know how easy and what I would have to do to get the motor in.I was wondering if I could use the series2 bottom end with the series1 top end?Idk anything about these cars I have been googling the hell out of it to no help.
  2. #2 Re: Difference between series 1 and series 2
    GTP Level Member Scimmia's Avatar
    QCA, IA
    The series 1 and series 2 are quite a bit different, no way the series 1 top end would fit the series 2 bottom, even the decks are different heights. Swapping the entire engine is possible, though. 3800pro should have some info on it.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: Difference between series 1 and series 2
    Jersey
    you might as well swap the trans as well, the 4t60e is weak. You would also need to convert it from obd1 to obd2. There would be alot of work cut out for you...it would be a cool project though.
    16' wrx sti- stock
  4. #4 Re: Difference between series 1 and series 2
    Would the plugs from the car plug in to the sensors on the s2,,maybe,idk.
  5. #5 Re: Difference between series 1 and series 2
    Jersey
    I doubt it, my series1 riviera that i had and my gp are like night and day of difference. I believe u might need a series II harness
    16' wrx sti- stock
  6. #6 Re: Difference between series 1 and series 2
    Hmm,if all the sensors are the same except for the actual plugs I could de-pin and put em in the other plugs instead of changin; the harness,maybe?
  7. #7 Re: Difference between series 1 and series 2
    Jersey
    as i said, its all different. The series 1 has an m62 s/c and is obd1, the series II has an m90 s/c and uses obd2
    16' wrx sti- stock
  8. #8 Re: Difference between series 1 and series 2
    Easiest way to do it would be get a harness that puts the pcm under the hood. Most Riv's retained the pcm in the passenger compartment while most other cars went to the engine compartment for the series 2's.
    Swap engine, trans, and wiring harness. Then make an adapter harness to interface between your engine bay and firewall connectors. Connect only the wires needed like speedo, cruise, gauges etc.
    Basically you'd map out the two harnesses and determine what needs to be connected. Probably about 10-15 wires.
    I know that I kinda make it sound easy, but when you really get into it, it's not tough. I've also done this type of thing as well as converted a 96 Riv to a 4T65 by adding 5 wires into the harnesses, changing the trans connector and swapping the pcm to a 97 for ease of programming.
  1. Series III downgrade to Series II
    By Rolling Thunder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2009, 02:12 PM
  2. Using Series III A/C Compressor on a Series II
    By Rolling Thunder in forum General Tech Discussion
    Last Post: 05-21-2009, 01:14 AM
  3. 3800 Series II MPG?
    By PsychoGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2009, 12:40 AM
  4. Series 1 2 or 3?
    By ratnick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-04-2009, 08:08 PM
  5. 3.8 series II sc blows smoke with rev
    By GTX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-16-2008, 01:09 PM
