Thread: High rpm engine problem
Results 1 to 20 of 29
  1. #1 High rpm engine problem
    seattle
    Good morning all. This is my first post, so thank you for providing this forum for all its wealth of information. I have a 2000 GTP. Under 1/2 and 3/4 throttle the car has no problems. Under WOT the car has no power and seems to miss. I immediately figured it was a fuel supply problem and changed the fuel filter. No help. I checked fuel pressure at the rail and it was within specs. The one interesting thing it did do though, was it wouldn't hold pressure after the key was turned off. I immediately figured it was an injector. The problem with that is there are no idle issues and it does not blow any smoke upon start-up. New plugs and wires, new air filter and no codes are being thrown. I know this car has a 2 speed fuel pump but I'm not sure how to test if that is working correctly. Could a bad fuel regulator cause this problem? As you all know parts are pretty expensive so I am hoping someone can steer me in the right direction before I just start replacing stuff. Let me know if there is any other information I can give to help you aid me with this problem. Any help you can send my way will be much appreciated.
  2. #2 Re: High rpm engine problem
    so it bogs down under WOT?
    it thats the case, you might have a clogged cat.
  3. #3 Re: High rpm engine problem
    seattle
    High flow cat installed a year ago.
  4. #4 Re: High rpm engine problem
    seattle
    An add on to anyone offering help. Just got it to throw a code. Went to O'Rilleys and scanned it. Code P0420. Do you think with the high flow cat I installed, the computer is trying to lean out the fuel because the oxygen sensor is bad? Just trying to give any info that might help. Thanks again.
  5. #5 Re: High rpm engine problem
    seattle
    working on car as I write this. pulled a couple of plugs and the engine is definitely running lean. any help would be great as to what to check next.
  6. #6 Re: High rpm engine problem
    Apr 2009
    stockton ca
    check for vac leaks a rich biased o2 sensor will force it to run rich lean aswell since the front o2 controls fueling
    Check it with a multi meter should bounce around from 200-800 milivolts if it doesnt thats part or your issue
    the highflow cat will through a code if the rear o2 code isnt taken care of and so on
    Highflow cats arent as effective as factory ones so the rear o2 will trigger the 420 cat efficientcy code
  7. #7 Re: High rpm engine problem
    seattle
    update: found bad plug and wire and replaced both. engine ran worse and threw a blinking ses light. did some more reading on this forum and decided to change all the coils. running better and now no ses light but the wot hesitation is still there. I think i had two problems and fixed only one of them. The problem must be fuel related. Does AutoZone have a scanner that works when the car is on? O'Rilleys only had a passive scanner. By the way checked for vaccum leaks like instructed and none found.
  8. #8 Re: High rpm engine problem
    London, Ontario, Canada
    I have the exact same issue. Car is running very lean I've replaced both o2 sensors and still a problem. Have a highflow cat in about a year ago. Wondering if my FPR is gone or if the really whiney fuel pump is the culprit. I have a tiny studder on idle almost like a miss and have replaced all the plugs and wires still there. Got no idea where to go hopefully someone can help before I start dumping un necessary money into this thing. The fuel filter was also changed about 5000kms ago that didn't help either. what is the best way to check for vac leaks all my lines seem fairly new I think they were replaced before I bought the car. Under WOT it seems like its missing something ..fuel or air Im assuming fuel sine i just put a brand new k&n in.
  9. #9 Re: High rpm engine problem
    Willoughby, Ohio
    symtoms sound like a cat...interesting tho...got me thinking
  10. #10 Re: High rpm engine problem
    Nov 2009
    Grand haven
    I would have to agree with cat. But you WOT might be your maf going bad too? What are your LTFT?
  11. #11 Re: High rpm engine problem
    Willoughby, Ohio
    if the MAF was bad the idle would be all over the place, maybe dirty tho?
  12. #12 Re: High rpm engine problem
    Escanaba,MI
    Just wondering if anyone found out what was wrong? My car seems to have some similar problems! Thanks guys
  13. #13 Re: High rpm engine problem
    seattle
    Still dealing with this problem thought i would throw it back and see if anyone has any new ideas. Replaced the pre cat O2 sensor but that didn't help. Seems like some others are dealing with the same problem and i was hoping they found a fix and can give some advice. Also, could any of you guys in the know, tell me if a slipping s/c belt might be the culprit. Would this cause the problems i am having? Thanks.
  14. #14 Re: High rpm engine problem
    GT Level Member backinblackgtp's Avatar
    Nov 2009
    centereach, NY
    does it happen all the time, or does it get better when the car warms up, my car bogs down when my cars cold and im trying to figure out what it is. its not a bad MAF ive had that, youre car would be all over the place at idle and almost stall. and a slipping supercharger belt, you would hear it, look at the belt see if its torn at all
  15. #15 Re: High rpm engine problem
    seattle
    car runs like it should when it's cold. When it comes up to temperature is when the problems start. When the engine is cold isn't the computer put into a closed loop system till the car comes up to temp. Trying to figure out why this problem only seems to happens when car is warm. The only other thing I can think of is the fuel pump. Can anybody explain how the two speed pump works and how i can test it. Replacement is the last effort due to cost.
  16. #16 Re: High rpm engine problem
    apply vacuum to the FPR.
    if fuel comes out then the FPR needs replacing.
    is the O2 wire touching any of your spark plugs?
  17. #17 Re: High rpm engine problem
    seattle
    will check the fpr after work tomorrow. thanks for the help. at this point i will try anything.
  18. #18 Re: High rpm engine problem
    Nov 2009
    centereach, NY
    hows youre fuel economy? code p0420m has nothing to do with youre car running this way, i had that issue for a long time before this happened to my car, its just the high flow cat flowing too much emissions, you can get that deleted if you know a guy with GM software. really seems like fuel pump, have you tried injector cleaner? and you might want to try a fuel system treatment too, i dont think its too much $.
  19. #19 Re: High rpm engine problem
    seattle
    Thanks for your input backinblack. When this whole thing started i put a new fuel filter on and put pour in fuel system cleaner. Guess I will try the fuel injector cleaner that you hook to the fuel rail. Can't imagine its a injector since there are no startup issues, no idle issues, no offline stumble, or any smoke upon startup. The car runs absolutely perfect and has no driveability issues except at WOT. 1/2 throttle and 3/4 throttle are just fine too, it's just when you smash it, the power goes away and you can smell it running hot. This weekend i am going to get elbow deep in the car and try to figure this out. I think i am going to get rid of the 9.00 a piece iridium plugs and see if that may be the problem too.
  20. #20 Re: High rpm engine problem
    Nov 2009
    centereach, NY
    have you scanned it for knock? i cant imagine what else it could be.
  1. Engine problem 3.4L dohc
    By sheepeater in forum 3.4L V6 (LQ1) DOHC
    Last Post: 09-08-2010, 11:49 PM
  2. Engine Misfiring @ High RPMs
    By skiderek in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-08-2010, 05:57 PM
  3. 98 GTP high idle problem
    By mikegtp in forum General Tech Discussion
    Last Post: 10-09-2009, 02:05 PM
  4. engine idling high
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2009, 11:49 PM
  5. Engine problem???
    By WHITEHORSE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-07-2009, 11:11 PM
