Thread: zero boost on aftermarket guage
Results 1 to 13 of 13
  1. #1 zero boost on aftermarket guage
    GT Level Member hourang's Avatar
    commerce, mi
    so i finally hooked up my boost guage on friday. its an Equuis from oreillys. so it reads zero when not running, -15 to -19 at idle, -10 and normal throttle, and ZERO and WOT... DIC guage reads all bars full boost. and i know im getting boost because its fast and feels like the boost is kicking in and the blower is loud. did i hook it up to the wrong vacuum source? i figured any vacuum source would get boost, maybe not. i hooked it up to the easiest spot to reach since i was being rushed to leave by my wife. its that 3 connecting thing on top of the blower, its connected inline of the middle one, the one next to the line that goes to the bbv. im thinking of trying the bbv line and if that doesnt work then the one by the map sensor?
    -Jeff
    98 GTP Black 4dr - fully loaded - short ram intake, tinted tails, hole in resonator.
    sold 98 camaro ss - 6spd fully loaded - cam, intake, exhaust, ford 9in rear 4.11s, 6point chromoly cage, tnt 150shot nitrous, nittos, etc.
  2. #2 Re: zero boost on aftermarket guage
    Apr 2009
    stockton ca
    it might be where you sourced the vac from
    I would put a T in at the line right at the map sensor coming out the back
  3. #3 Re: zero boost on aftermarket guage
    Outer Space
    Quote Originally Posted by TorqueAutoMotiv View Post
    Exactly what I did!
    02 GTP 13.6 @ 100mph - SOLD
  4. #4 Re: zero boost on aftermarket guage
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by hourang View Post
    Think this through, don't just try this and that. That vacuum manifold you connected to is before the blower rotors, so how's it supposed to see boost?
    2001 Buick Regal LS - Almost Stock
  5. #5 Re: zero boost on aftermarket guage
    commerce, mi
    Quote Originally Posted by Scimmia View Post
    im too new to these cars to know the routing of the lines, havent messed with it much besides the air filter. its right before the bbv, so the bbv doesnt see boost? i knew this was most likely the problem and would have fixed it but i wanted more information on why so i can learn more about the complex vacuum system on these cars.
    -Jeff
  6. #6 Re: zero boost on aftermarket guage
    QCA, IA
    The black canister is just the actuator for the BBV, so no, it doesn't see boost. It's really not that complicated, you have the inlet for the supercharger, the rotors, and the outlet. You're connected to the inlet, which is before the air is compressed. You need to connect AFTER the rotors.
  7. #7 Re: zero boost on aftermarket guage
    commerce, mi
    ah i see. thanks!
    -Jeff
  8. #8 Re: zero boost on aftermarket guage
    GT Level Member BoostedComp's Avatar
    Youngstown
    true story ^^^ follow the t fitting from under the snout of the blower and put a t line somewhere back there.
  9. #9 Re: zero boost on aftermarket guage
    commerce, mi
    stupid t fittings. tried to tap into the t fitting under the snout and the t fitting just broke like it was plastic. have it rigged with electrical tape right now, but will need to replace them. anyone replace all their plastic lines and know what size t fittings and hoses you need? i know there are 2 different sizes i need because the connector under the snout is big and the one on the fpr? is small.
    -Jeff
  10. #10 Re: zero boost on aftermarket guage
    Outer Space
    i used rubber hose and some plastic vac line T's I got from the autoparts store.
  11. #11 Re: zero boost on aftermarket guage
    commerce, mi
    Quote Originally Posted by Lawngoose View Post
    did you have to get 2 different sizes?
    -Jeff
  12. #12 Re: zero boost on aftermarket guage
    Outer Space
    No, i used some small rubber hose... maybe 1/8" ... stuck it over the nipple under the snout... then using the plastic, barbed T... used two more pieces of rubber hose to connect to the plastic lines.
    Would it help better if I got you a picture?
  13. #13 Re: zero boost on aftermarket guage
    commerce, mi
    oh im saying i want to replace all the plastic lines with rubber and brass Ts.
    -Jeff
  1. DIC boost guage half filled WOT
    By Perry125 in forum General Tech Discussion
    Last Post: 11-02-2012, 11:28 PM
  2. aftermarket boost guage?
    By reallyfast1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2010, 05:42 PM
  3. Boost guage installed..took every bit of 15 min..
    By Boosted02GTP in forum General Tech Discussion
    Last Post: 03-15-2010, 01:29 AM
  4. installing a boost guage
    By L KELLS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-02-2010, 09:50 AM
  5. Most Accurate Boost Guage?
    By RNUOVR in forum Off Topic Discussion
    Last Post: 01-07-2008, 03:38 PM
