Thread: Boost guage installed..took every bit of 15 min..
Results 1 to 20 of 31
Threaded View
Boosted02GTP Boost guage installed..took... 03-11-2010, 06:42 PM
Boosted02GTP Re: Boost guage... 03-11-2010, 06:50 PM
Joe m Re: Boost guage... 03-11-2010, 07:11 PM
JoRoW99 Re: Boost guage... 03-11-2010, 09:53 PM
Boosted02GTP Re: Boost guage... 03-11-2010, 10:17 PM
matt5112 Re: Boost guage... 03-11-2010, 10:18 PM
Boosted02GTP Re: Boost guage... 03-11-2010, 10:37 PM
matt5112 Re: Boost guage... 03-11-2010, 10:38 PM
Boosted02GTP Re: Boost guage... 03-11-2010, 10:40 PM
ZR1Vette09 Re: Boost guage... 03-11-2010, 10:41 PM
SilvaMan61 Re: Boost guage... 03-11-2010, 10:57 PM
matt5112 Re: Boost guage... 03-11-2010, 10:59 PM
Boosted02GTP Re: Boost guage... 03-11-2010, 11:00 PM
Boosted02GTP Re: Boost guage... 03-11-2010, 11:04 PM
matt5112 Re: Boost guage... 03-11-2010, 11:14 PM
Boosted02GTP Re: Boost guage... 03-12-2010, 12:19 AM
matt5112 Re: Boost guage... 03-12-2010, 12:21 AM
silverstreak Re: Boost guage... 03-12-2010, 12:25 AM
97gtsc Re: Boost guage... 03-12-2010, 01:02 AM
nawarkk Re: Boost guage... 03-12-2010, 01:11 AM
JoRoW99 Re: Boost guage... 03-12-2010, 01:50 PM
blowfishRus6 Re: Boost guage... 03-12-2010, 02:12 PM
Boosted02GTP Re: Boost guage... 03-12-2010, 05:59 PM
JoRoW99 Re: Boost guage... 03-13-2010, 07:42 PM
blowfishRus6 Re: Boost guage... 03-12-2010, 10:19 PM
Colossus Re: Boost guage... 03-13-2010, 01:14 AM
Boosted02GTP Re: Boost guage... 03-14-2010, 02:41 AM
speedemongtp Re: Boost guage... 03-14-2010, 02:54 AM
kfish Re: Boost guage... 03-15-2010, 01:20 AM
98GTPCALGARY Re: Boost guage... 03-15-2010, 01:26 AM
98GTPCALGARY Re: Boost guage... 03-15-2010, 01:29 AM
  1. #1 Boost guage installed..took every bit of 15 min..
    SE Level Member Boosted02GTP's Avatar
    Feb 2009
    Long Grove IL.
    So I went pepboys and got a cheapo $28, 20psi gauge. About 7' of small tubing and a set of the T connectors to tap into the line..
    Well that took me all of 15 min. to hook it up and rout the line through the car..I took it for a test drive and got a video to show it working. I still have to splice it into the dim switch and ground it..
    The hardest part of this install is the location I picked. I'm relocating the fog light switch and mounting the gauge just above the left driver side air vent..I think this is a perfect location for me because I don't want the piller pod. It's a little more sleeper like I guess..I have to take my dremal to the outer/inner dash peceies to get the gauge to fit. I'll be spending some time this weekend with a sanding wheel to get a clean fit/finish. I'll follow with pics this Saturday or Sunday. I'll also upload the video from my phone asap..
    Ohhhh And when you put it to the floor the car boosts 5psi and spikes at 7psi at around 5,000rpms or so and holds until it shifts. Sounds about right for the 3.8" pulley on a stock car?! At idle it sits at about -19#'s or whatever the measurement is for the vacuum side.
    2002 GTP coup 14.6 @ 94mph stock baseline 5-7psi.
    Headers w/o cat, plugs, fwi, 180* t-stat, 3.4, mail-in tune. 13.9 @ 99.75mph 2.2 60'..seeing only 7psi and a fresh set of weatherman snow tires
  1. DIC boost guage half filled WOT
    By Perry125 in forum General Tech Discussion
    Last Post: 11-02-2012, 11:28 PM
  2. aftermarket boost guage?
    By reallyfast1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2010, 05:42 PM
  3. installing a boost guage
    By L KELLS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-02-2010, 09:50 AM
  4. Most Accurate Boost Guage?
    By RNUOVR in forum Off Topic Discussion
    Last Post: 01-07-2008, 03:38 PM
