Thread: DIC boost guage half filled WOT
Results 1 to 8 of 8
  1. #1 DIC boost guage half filled WOT
    GT Level Member Perry125's Avatar
    maryland
    Hello, when i am full steam ahead, the boost gauge in the DIC only has half of the bars lit up?
    It feels quick.. and i can hear the blower. is this just a gauge problem?
    thanks
  2. #2 Re: DIC boost guage half filled WOT
    Jul 2008
    sumter,south carolina
    id almost bet 100 bucks that u have a vaccum leak. My T boot connection that goes on the intake right under the supercharger snout was disconnected and i had the same problem with boost indicator. If the leak gets bad enough it will throw a throttle position sensor code. Anyways there is like 4 or 5 vac lines if im not mistaken. just trace them all out and look for leaks or even completely disconnected lines.
    02 GTP with mods 05 GP for DD
  3. #3 Re: DIC boost guage half filled WOT
    maryland
    Thanks, ill check it out.
    I hear a noise that sounds like grinding almost since i put my intake on...
    is that just induction noise or what? I thought you could hear leaks sometimes.
  4. #4 Re: DIC boost guage half filled WOT
    Jul 2008
    induction noise is correct, should be really loud on cold start then calms down a lil after it reaches operating temp. mine does it to when i get on or off of the throttle.
  5. #5 Re: DIC boost guage half filled WOT
    just get a real boost gauge instead of watching that useless DIC display.
  6. #6 Re: DIC boost guage half filled WOT
    maryland
    Yeah not a bad idea, im thinking about getting a everything guage that displays boost and everything i would ever want to know.
    So is that gauge not really even accurate?
  7. #7 Re: DIC boost guage half filled WOT
    Wichita
    Probably pretty accurate until you change pulley sizes.
  8. #8 Re: DIC boost guage half filled WOT
    Nov 2012
    los angeles, ca
    so how did you fix your problem? i have a stock gtp other than intake and also have half boost problem was boosting full bars last week
  1. Getting half boost at the gauge.
    By falcz420 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2012, 02:56 PM
  2. aftermarket boost guage?
    By reallyfast1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2010, 05:42 PM
  3. Check tire pressure keeps coming on after i have filled tires..
    By MattTheBaker123 in forum Tires & Wheels
    Last Post: 10-28-2009, 07:18 PM
  4. Most Accurate Boost Guage?
    By RNUOVR in forum Off Topic Discussion
    Last Post: 01-07-2008, 03:38 PM
