Thread: valve springs
Results 1 to 15 of 15
  1. #1 valve springs
    GT Level Member sdenton8's Avatar
    marshalltown, iowa
    G8 GT valve springs can be used with a rocker setup right? What is the seat pressure on those springs? and I can use grandprix retainers and locks right?
  2. #2 Re: valve springs
    Donating Users
    South Deerfield, MA
    I just went through researching this last week and I was told you use the current L67 locks, but you need the L76 retainers to go with the L76 springs.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  3. #3 Re: valve springs
    marshalltown, iowa
    Ok thanks for the reply. I can get the springs cheaper through work. I have the steel retainers that zzp sells for the upgraded springs. Would those work with the G8 springs? Are they closer to the 90# or the 105# spring rate?
  4. #4 Re: valve springs
    Charles City, IA
    Yes those retainers work they are all the lsx style springs.
    SMGPFC Two Nipple General
  5. #5 Re: valve springs
    marshalltown, iowa
    Sweet I have the retainers already since I can use them. I can get the G8 springs thru work.
    Is there a big diff between the modded 1.9 rockers and the roller 1.95 rollers? I know the rollers cost more. These are gonna be for the top end performance.
  6. #6 Re: valve springs
    Charles City, IA
    For the price no. Gains are small, but they sure do look cool. I will get some stock ratio rollers for my car some time.
  7. #7 Re: valve springs
    marshalltown, iowa
    Yea thats why I'm thinking about getting the rollers cuz they are easy on the valvetrain and mite as well go big or go home.
    Does anyone know the seat pressure of the G8 springs?
  8. #8 Re: valve springs
    Charles City, IA
    around 90# IIRC.
  9. #9 Re: valve springs
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by sdenton8 View Post
    90# seat pressure, but with a roughly stock spring rate.
    2001 Buick Regal LS - Almost Stock
  10. #10 Re: valve springs
    marshalltown, iowa
    Thanks guys. What would be better the G8 or 105 crow springs for 1.95 rollers?
    Just decided to go with the biggest lift rocker since I dont want to cam it.
  11. #11 Re: valve springs
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    90 will work but i would just do 105s
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  12. #12 Re: valve springs
    Donating Users
    South Deerfield, MA
    Just to let you know, the 1.95's are discontinued, but the wbody store says they still have them in stock. Jump on them soon since if you really want a set.
  13. #13 Re: valve springs
    marshalltown, iowa
    Sounds like I'm getting me a set of 105s. I looked at work and we cant even get them which is kinda wierd.(I work at a Advanced Auto)
    So I'll just get those instead. I'll check in on those and see if they still have them. I hope those will help me hit mid 13's....
  14. #14 Re: valve springs
    Jersey
    L76 springs work well, 105's really aren't needed for 1.9 rockers, but if you really want 105's then get crow 105's
    16' wrx sti- stock
  15. #15 Re: valve springs
    marshalltown, iowa
    Well how much are the G8 springs? and where can I get them other then the dealer?
  1. Valve Springs
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2010, 07:05 PM
  2. TDC Valve springs.
    By TheOtherNick in forum Off Topic Discussion
    Last Post: 12-23-2009, 07:12 PM
  3. valve springs
    By 99prixgt in forum General Tech Discussion
    Last Post: 05-07-2009, 10:33 PM
  4. LS6 Valve Springs?
    By projectGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-23-2009, 04:21 PM
